crwdns2959928:0crwdne2959928:0 ↓The screws in the front panel are coated in Teflon, making them harder to unscrew. To make the screws easier to remove, you should apply a Blaster onto the screws and let the blaster settle in for about two minutes.
Remove the six 16mm #3 Hex head screws located on the front panel.
Grab the front panel and gently lift it up to the side.
Remove the two, 19 mm Phillips #2 screws holding the ignition.
