Hover-1 Titan Left Gyroscope Replacement
Jessica Ouyang
crwdns2944107:0crwdnd2944107:0Jessica Ouyangcrwdnd2944107:0crwdnd2944107:0crwdnd2944107:04crwdnd2944107:0crwdne2944107:0
crwdns2944111:0N'w 5, 2018crwdne2944111:0
10 - 20 crwdns2931279:0crwdne2931279:0
crwdns2937801:0crwdne2937801:0
crwdns2942287:0crwdne2942287:0
If your hoverboard will not turn on, retain a charge, move, or spin properly, use this guide to help replace your Hover-1 Titan gyroscope/motherboard.
  • Phillips #1 Screwdriver
  1. Hover-1 Titan Left Gyroscope Replacement, Bottom Left Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Titan Left Gyroscope Replacement, Bottom Left Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the hoverboard so the bottom is facing up.
    • The left side is the side that has the charge port. There is also an "L" on the metal plate underneath the wires.
  2. Hover-1 Titan Left Gyroscope Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Titan Left Gyroscope Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #1 screwdriver, remove the two 14 mm screws located closest to the center of the hoverboard.
    • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove two 15 mm screws located closest to the wheel.
  3. Hover-1 Titan Left Gyroscope Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hover-1 Titan Left Gyroscope Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hover-1 Titan Left Gyroscope Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grip the bottom left panel and lift up to remove.
  4. Hover-1 Titan Left Gyroscope Replacement, Left Gyroscope and Motherboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Titan Left Gyroscope Replacement, Left Gyroscope and Motherboard: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the battery from the gyroscope by holding the yellow connector and pulling apart.
  5. Hover-1 Titan Left Gyroscope Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hover-1 Titan Left Gyroscope Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hover-1 Titan Left Gyroscope Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove four 12 mm Phillips #1 head screws from the corners of the green gyroscope/motherboard.
  6. Hover-1 Titan Left Gyroscope Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Titan Left Gyroscope Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the bottom right connector by squeezing it and pulling it away from the board.
  7. Hover-1 Titan Left Gyroscope Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Titan Left Gyroscope Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the light connector by squeezing it and pulling away from the board.
  8. Hover-1 Titan Left Gyroscope Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Titan Left Gyroscope Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the blue and white wires by squeezing the connector and pulling away from the board.
  9. Hover-1 Titan Left Gyroscope Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Titan Left Gyroscope Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the small white connector by squeezing it and pulling away from the board.
  10. Hover-1 Titan Left Gyroscope Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Titan Left Gyroscope Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the plug in the red connector.
    • The red plug is glued to the board, so this step will require extra force.
  11. Hover-1 Titan Left Gyroscope Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Titan Left Gyroscope Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the charging cable connector by squeezing it and pulling it away from the board.
  12. Hover-1 Titan Left Gyroscope Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Cut the cable tie.
    • Unplug the remaining wires.
    • The connectors for the remaining wires are in the rubber covers.
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
Jessica Ouyang
crwdns2935283:010/08/18crwdne2935283:0
619 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S15-G4, White Fall 2018 crwdns2935289:0Cal Poly, Team S15-G4, White Fall 2018crwdne2935289:0
CPSU-WHITE-F18S15G4
I’ve got an active broken on the cover not the one to to speaker the other one. Does anyone know where is terminates. I can’t see where it came from. It can only reach the circuit board or the active of the speaker.
Mark - crwdns2934203:0crwdne2934203:0
Where do you buy the board?
eden11 - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 23
crwdns2942667:0crwdne2942667:0 1,286
