Hover-1 Charger Battery Replacement
  1. Hover-1 Charger Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Charger Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the hoverboard over so that the warning label is facing up.
    • Remove the twelve 12 mm screws with a Phillips #2 screwdriver.
    • Remove the four 10 mm screws with a Phillips #2 screwdriver.
    • The screws nearest to the wheels may be hard to access. Be sure to use a long, thin screwdriver.
  2. Hover-1 Charger Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the right cover away from the hoverboard to expose the battery.
  3. Hover-1 Charger Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Charger Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the battery by disconnecting the two pronged black and yellow cable.
  4. Hover-1 Charger Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the left cover away from the hoverboard.
  5. Hover-1 Charger Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Charger Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the two pronged black and yellow cable.
    • Thread the cable through the middle cylinder of the hoverboard.
  6. Hover-1 Charger Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Charger Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the four 10mm screws that are holding the battery casing in place. Use a Phillips #2 screwdriver.
    • If there is a zip-tie connecting the wires together, carefully cut it with a wire cutters.
  7. Hover-1 Charger Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hover-1 Charger Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hover-1 Charger Battery Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • On the battery side, unplug the white five pin connector on the circuitboard.
    • Unplug the black, yellow, green and red connector on the circuitboard.
  8. Hover-1 Charger Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Move all the loose cables to the side. Pull the battery casing away from the battery.
  9. Hover-1 Charger Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the opening tool to remove the battery from the metal casing.
    • The battery is stuck to the metal casing with strong adhesive; do not be afraid to apply a strong force with the opening tool.
  10. Hover-1 Charger Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery.
Melanie Hardell
crwdns2935283:010/10/19crwdne2935283:0
505 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S12-G1, Regan Fall 2019 crwdns2935289:0Cal Poly, Team S12-G1, Regan Fall 2019crwdne2935289:0
CPSU-REGAN-F19S12G1
Can I replace my battery 25.2v to a 36v.
Airie Green - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 23
crwdns2936753:030crwdne2936753:0 115
crwdns2942667:0crwdne2942667:0 9,122
