The belt on the Hoover Power Path Pro Advanced allows the brush rolls to spin while the power is on. If the brush rolls are not spinning, then it is likely that the brush rolls need to be replaced.
Lay the cleaner down horizontally with its wheels closest to the floor.
Hold the lower brush roll with both hands and pull outwards until it is detached.
Unscrew the 6 marked screws using a Phillips #2 head screwdriver.
Remove the brush roller.
Removing long roller brush is not required and can’t be done at this point because of belt.
Yuck!! I want to clean the transparent curved surface. I can’t get at it.
Use a long #2 Philips head screwdriver to remove the 8 numbered screws on the bottom of the cleaner.
The 8 screws are not all shown here. There are arrows with numbers pointing at all of them on the dark plastic. The two shown here in red are labelled on the clear plastic.
Pull the red handle shown to remove the front suction unit from the cleaner.
Unscrew the Phillips #2 screw at the bottom of the hose.
Push down on the handle release button. Pull and disconnect the edge of the top cover on the side of the handle release button.
Repeat the above step for the "On/Off" button.
What a load off bollocks following this instruction broke my Hoover
I followed your instructions and after pressing the release button and the start button erasing the clips broke my Hoover as it's not as easy as you
It is impossible to remove the top cover...!!!!! I'm breaking the vacuum!!! you need to give better instructions!!!
This guy forgot about removing the entire underside first...also snapped off a plastic screw casing. Bollocks is correct. There should be 10 or 11 steps. Take off the bottom casing, about 7 screws I believe.
Gently grab the belt and pry it off from the rollers.
crwdns2947412:05crwdne2947412:0
Who the heck made this so hard,
Day 5 and 4 people, I still can’t lift the top off to be able to replace belts. Is there a video
Just understand there are more screws to remove then what is described in these 8 steps. Once you removed ALL the screws then the plastic lid comes right off.
How the back do you put the too belts on and seeing how the bag came with two and both were wide what size is the one that goes around the roller the other one control the circle brushes this is one of the most difficult belt change I've bad and I'm counting on car to
There is only 8 screws you need to remove. The diagram makes it hard to know but there are two top ones Directly under the brush ! Once you get them out then comes off no problem at all.
I have to rollers on mine.
poco24 - crwdns2934203:0crwdne2934203:0
I have two rollers on mine.
