Hoover Power Path Deluxe FH50951 Nozzle Replacement
  1. Hoover Power Path Deluxe FH50951 Nozzle Replacement, Brush Roll: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hoover Power Path Deluxe FH50951 Nozzle Replacement, Brush Roll: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hoover Power Path Deluxe FH50951 Nozzle Replacement, Brush Roll: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four 18.6 mm screws labeled 1-4 using a Phillips #1 screwdriver.
    • Remove the piece that was being held down by those screws.
  2. Hoover Power Path Deluxe FH50951 Nozzle Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hoover Power Path Deluxe FH50951 Nozzle Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hoover Power Path Deluxe FH50951 Nozzle Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four 18.6 mm screws with arrows listing 5-8 using a Phillips #1 screwdriver.
    • Remove the wheel assembly on the left side of the vacuum.
    • You may need a longer Phillips #1 screwdriver for screw #7.
  3. Hoover Power Path Deluxe FH50951 Nozzle Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up the belt to give enough slack to allow the brush roll to come out.
    • While lifting the belt, pull/push upward away from the cleaner to pop it out.
    • It may seem like the brush rolls wont come out but just put more force into it.
  4. Hoover Power Path Deluxe FH50951 Nozzle Replacement, Belt: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hoover Power Path Deluxe FH50951 Nozzle Replacement, Belt: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently slide the belt off of the motor shaft and lift it out of the vacuum.
    • Loop one end of the new belt around the motor shaft, making sure it sits securely in the groove.
    • Ensure the belt is securely placed in the correct slot on both the motor shaft and the brush roll. A loosely installed or improperly positioned belt can slip, break, or prevent the brush roll from spinning correctly, potentially damaging your vacuum. Double-check that the belt is aligned and tensioned properly before reassembling the vacuum.
  5. Hoover Power Path Deluxe FH50951 Nozzle Replacement, Water Dispenser: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hoover Power Path Deluxe FH50951 Nozzle Replacement, Water Dispenser: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 18.6 mm screws using a Phillips #1 screwdriver.
    • Remove the wheel assembly on the right side of the vacuum.
  6. Hoover Power Path Deluxe FH50951 Nozzle Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hoover Power Path Deluxe FH50951 Nozzle Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hoover Power Path Deluxe FH50951 Nozzle Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 12.6 mm screws using a Phillips #1 screwdriver.
    • Remove the piece.
  7. Hoover Power Path Deluxe FH50951 Nozzle Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Hold the dispenser in one hand and the tube that is attached to the bottom in the other hand and pull.
    • It should just pull straight off, no twisting.
  8. Hoover Power Path Deluxe FH50951 Nozzle Replacement, Nozzle: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hoover Power Path Deluxe FH50951 Nozzle Replacement, Nozzle: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove two 18.6 mm screws and one 12.6 mm screw from the right side of the vacuum.
    • Lift the right brush roll housing away from the device.
  9. Hoover Power Path Deluxe FH50951 Nozzle Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hoover Power Path Deluxe FH50951 Nozzle Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 12.6 mm screws from the left-side brush roll housing and belt guide using a Phillips #1 screwdriver.
    • Lift the left-side brush roll housing and belt guide away together from the device.
  10. Hoover Power Path Deluxe FH50951 Nozzle Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hoover Power Path Deluxe FH50951 Nozzle Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hoover Power Path Deluxe FH50951 Nozzle Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the five 18.6 mm screws securing the nozzle to the vacuum using a Phillips #1 screwdriver.
    • By gripping the base of the device with your hands and pressing with your thumbs on the nozzle, press the nozzle away from the device.
    • Pull the nozzle away from the base to make removal easier.
  11. Hoover Power Path Deluxe FH50951 Nozzle Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hoover Power Path Deluxe FH50951 Nozzle Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully use the sharp end of a spudger to separate the hose gasket from a flange on the nozzle.
    • Use a circular motion around the edge of the flange to separate the gasket further.
    • With enough of the gasket lifted away from the flange, the nozzle can be pulled away from the hose.
Jon-Erik Hylle
crwdns2935283:010/31/24crwdne2935283:0
259 crwdns2915208:0crwdne2915208:0
Cuesta, Team 60-1, Krynen Fall 2024 crwdns2935289:0Cuesta, Team 60-1, Krynen Fall 2024crwdne2935289:0
CUESTA-KRYNEN-F24S60G1
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 95
