crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
If your Hoover Power Path Deluxe FH50951 is turned on, but it will not suck up anything on the ground, follow this troubleshooting guide.
Dirty Water Tank Not Installed Correctly
When reattaching the dirty water tank make sure to follow all of these steps to ensure good suction.
Dirty Water Tank is Full
When the dirty water tank is full, a float will rise that shuts off the air flow through the nozzle. Correct instructions on how to empty the dirty water tank are in this guide.
Dirty Water Tank is Clogged
For regular maintenance, the water tank should be cleaned every time after use. For proper instructions on how to clean visit this guide.
Air Path Blocked
Check the air path and if there is anything blocking it make sure to remove the debris from the path. In case the nozzle needs replacing, use this guide.
Kiersten Liebig
crwdns2935283:010/31/24crwdne2935283:0
197 crwdns2915208:0crwdne2915208:0
Cuesta, Team 60-1, Krynen Fall 2024 crwdns2935289:0Cuesta, Team 60-1, Krynen Fall 2024crwdne2935289:0
CUESTA-KRYNEN-F24S60G1
crwdns2942667:0crwdne2942667:0 156
