Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement
  1. Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Disconnect the spark plug: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Disconnect the spark plug: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin, make sure the engine is switched off and cool to the touch.
    • Grab the plastic housing at the end of the spark plug wire and pull firmly to disconnect it.
  2. Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Restrict fuel flow: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the fuel cutoff valve to the off position to restrict fuel flow during disassembly.
    • Turn the fuel cutoff valve clockwise so the handle becomes vertical.
  3. Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Disconnect the fuel tank: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Disconnect the fuel tank: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Disconnect the fuel tank: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use needle nose pliers to compress and slide the tube clamp away from the cutoff valve's fitting.
  4. Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Residual fuel may leak out of this hose. Be ready to catch any spillage.
    • Disconnect the fuel line from the cutoff valve.
  5. Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Disconnect the brake cable: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use needle nose pliers to squeeze the two locking tabs on the brake cable latch.
  6. Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull to unlatch the cable sheath.
    • Pull the brake cable away from the motor.
  7. Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the cable towards the cable anchor to give it enough slack to be removed.
    • Remove the brake cable from the motor.
  8. Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Disconnect the pull start cord: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Disconnect the pull start cord: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Disconnect the pull start cord: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the pull start cord out of the small opening on the handle post and remove it.
  9. Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Remove the fan cover: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 10 mm nuts securing the fan cover.
  10. Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the fan cover.
    • The fuel tank is connected to the fan cover. They will both come out as one unit.
  11. Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Remove the cooling fan: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 19 mm nut securing the flywheel and cooling fan to the motor.
  12. Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the washer on top of the cooling fan.
    • Remove the cooling fan.
  13. Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Loosen the flywheel: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Loosen the flywheel: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Caution: The flywheel may come loose at any time during this step, potentially sending itself and the puller into the air. Before you begin this step, be sure to wear PPE.
    • Use a universal puller to loosen the flywheel from the tapered pressure fit on the end of the crankshaft.
    • Attach the universal puller arms underneath the denoted "puller" sections on the flywheel.
    • Use a wrench to torque down the puller to slowly loosen the flywheel.
    • This may take a lot of force.
    • If the flywheel seems to become stuck after significant pressure is applied with the universal puller, use a blowtorch to slowly apply heat where the flywheel contacts the crankshaft.
    • The flywheel will "pop" off the crankshaft once loose.
  14. Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Remove the flywheel: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Remove the flywheel: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Remove the flywheel: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the flywheel.
    • If the flywheel became deformed at all during the last step, it will need to be replaced before reinstallation.
    • During reassembly, make sure to align the flywheel with the flywheel key.
  15. Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Remove the flywheel key: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Remove the flywheel key: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use needle nose pliers to remove the flywheel key from its slot in the crankshaft.
    • During reinstallation, make sure the key is fully seated in the slot. Otherwise the flywheel will not fit correctly.
Carsten Frauenheim
145,380 crwdns2915208:0crwdne2915208:0
crwdns2935297:0424crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,530crwdne2935297:0
These instructions were very good for me. My Honda lawn mower is not starting. I presume it is a sheared key, but the key doesn't have jagged edges like it broke or any stress was applied to it.
Bryan Abney - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 51
crwdns2942667:0crwdne2942667:0 2,944
