Honda Fit Reset Oil Life Indicator Replacement
    • Turn the key in the ignition to the run position (right before the start position)
    • Press the SELECT/RESET knob repeatedly until the engine oil life indicator is displayed.
    • Press and hold the SELECT/RESET knob for more than 10 seconds. The engine oil life indicator and the maintenance code(s) will blink.
    • Press and hold the SELECT/RESET knob for more than 5 seconds. The maintenance items code(s) will disappear, and the engine oil life will reset to 100%.
    • Turn the key in the ignition to the off position, and then start the engine to verify the indicator has been reset.
You did it!
crwdns2935229:020crwdne2935229:0
Jasen Friedle
crwdns2935283:008/25/14crwdne2935283:0
3 872 crwdns2915208:0crwdne2915208:0
Great. I did it—and I’m a girl!!
pthompso99 - crwdns2934203:0crwdne2934203:0
in my case i followed the step through. 100% oil life was achieved but when i turn the ignition off and turn it back on to verify, it goes back to 15%
Esosa Aghimien - crwdns2934203:0crwdne2934203:0
And how can I start the car that it won't start
sbukataake - crwdns2934203:0crwdne2934203:0
Have you tried changing your blinker fluid?
neegnorg -
crwdns2936753:07crwdne2936753:0 76
crwdns2936753:030crwdne2936753:0 431
crwdns2942667:0crwdne2942667:0 80,965
