Some possible symptoms which could show that your battery needs to be replaced:
- Battery percentage remains low, even after charging.
- The tablet dies when it still has a lot of battery life.
- The tablet becomes hot after using for a short period of time.
If you experience these symptoms, you might need to get a new battery. This battery replacement guide will walk you through the steps on how to remove necessary components in order to get to the battery. Replacing the battery is a moderate five step process using the necessary tools (refer to tools list).
Use the plastic opening tools from iFixit to safely remove the screen from the back of the device.
Lift and remove screen to reveal the battery and circuit board as seen in the picture.
Preparing to remove the speaker.
Use spudger to remove the speaker from the back casing of the device.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Remove the black strips as shown in the picture from the wires using the tweezers.
Carefully use the spatula and spudger from iFixit to remove the battery from the device.
Heat the soldering iron to operating temperature.
Locate the black and red wires on the top of the circuit board.
Using the soldering iron, apply heat to the shiny solder point on the circuit board (Circled on the picture).
Be sure to perform this task for both the black and red wires.
