Hemming Pants
  1. Hemming Pants, Hemming Pants: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Begin by assessing the pants' current length. This is best done by wearing the pants along with an appropriate pair of shoes.
    • Wearing pants barefoot or with high heels will affect their length relative to the floor.
    • It's helpful to have a second person assist with this step and the two that follow.
  2. Hemming Pants: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hemming Pants: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hemming Pants: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Fold the cuff of one pant leg inward, and adjust it to the desired length.
    • Insert two or three pins to hold the cuff in position.
    • The pins should be placed parallel to the new fold.
    • With the pins in place, verify that the length is correct.
    • Make any final adjustments to the length as needed.
  3. Hemming Pants: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • On a flat, clean surface, lay the pants down on their side with the newly shortened pant leg on top.
    • Using a ruler, note the distance from the edge of the old cuff to the edge of the new cuff.
    • Repeat the measurement several times along the width of the cuff, making sure the new hemline is perfectly even.
  4. Hemming Pants: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hemming Pants: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Thread the sewing machine, using a thread color that matches your garment's fabric as closely as possible.
    • Sewing machine setup varies from one model to another. Consult your sewing machine manual for precise instructions.
    • Place the first cuff on the sewing machine, and position the sewing needle between one of your pins and the edge of the cuff.
  5. Hemming Pants: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hemming Pants: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently depress the foot pedal and begin sewing.
    • Be sure the needle penetrates the pant leg on only one side. It may be easier to position the pant leg around the arm of the sewing machine with the table removed. If you sew through both layers, you will sew the pant leg shut!
    • Pause when you reach a pin, and remove it before continuing.
    • Do not attempt to sew over any pins. Hitting a pin can bend or break the sewing machine needle.
  6. Hemming Pants: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hemming Pants: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Continue sewing all the way around the cuff, until you reach the first few stitches.
    • Sew over the first few stitches to prevent the stitches from unraveling.
  7. Hemming Pants: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Raise the presser foot, and remove the pants from the sewing machine.
    • Clip any threads.
  8. Hemming Pants: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hemming Pants: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hemming Pants: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the cuff over so that the extra length of the hem folds out.
    • Clip the extra length, leaving about a half inch of fabric beyond the seam.
    • Be sure to only cut through one layer of the fabric—the excess fabric. Do not cut through the pants.
    • This step is optional. If you are hemming pants for a growing kiddo, leaving the excess length allows you to rip the seam and magically lengthen the pants later on.
  9. Hemming Pants: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hemming Pants: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hemming Pants: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Set your sewing machine to a zigzag stitch.
    • Insert the freshly cut edge of the hem into the sewing machine.
    • Be sure to only insert one layer of fabric—the hem—or you will sew through the outer, visible layers of the pants.
  10. Hemming Pants: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hemming Pants: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Sew around the hem, as close to the edge as possible.
    • Zigzagging the edge prevents the edge from unraveling.
  11. Hemming Pants: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hemming Pants: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the presser foot and remove the pants from the sewing machine.
    • Clip any excess threads.
Repeat steps 5-19 for the second pant leg.
Brittany McCrigler
crwdns2935283:003/05/12crwdne2935283:0
89.981 crwdns2915208:0crwdne2915208:0
crwdns2935297:0142crwdne2935297:0
Staff
crwdns2931471:0120crwdne2931471:0
crwdns2935297:020.067crwdne2935297:0
crwdns2936753:07crwdne2936753:0 40
crwdns2936753:030crwdne2936753:0 153
crwdns2942667:0crwdne2942667:0 18,150
