The current printer being worked on is a Tevo Tarantula DIY 3D printer, here are some other printers that will work with this guide:
- Creality Ender 3
- Anet A8
- Anycubic i3 Mega
- Prusa i3
This guide will help to replace a burnt or faulty connection on the heated bed due to cable strain or when using too high of a temperature. We will be replacing the connection with a much heavier duty connector that will last longer.
Before you follow this guide, ensure that it is the heated bed connection and not the controller board connection. If it is the latter, you may wish to use the soldering technique guide in order to desolder and replace the terminals or solder joints as required.
Disconnect all power before performing any maintenance on the printer to avoid electrocution.
Remove the four screws from the corners of the panel covering the controller board.
Locate the heated bed and temperature sensor connectors.
Remove the connection for the heated bed.
Remove the connector for the temperature sensor.
Remove four thumb nuts from the corners of the heated bed.
Remove the heated bed from the Y-carriage.
Desolder the damaged cable or connector.
crwdns2935267:0crwdne2935267:0Desoldering Pump$3.99
Remove the old solder by using a solder pump or solder wick.
Re-tin the pads with fresh solder.
Strip 1/4" from both ends of the wire and tin.
Solder the wire onto the heated bed.
Apply Kapton Tape over the connection.
Solder an XT60 connector to the other end of the wire.
Reinstall and calibrate the heated bed.
To reassemble your device, follow these instructions in reverse order. You may want to calibrate the Z-axis end stops and re-level the bed before printing.
