Harman Kardon Onyx Studio 2 Front Panel Replacement
  1. Harman Kardon Onyx Studio 2 Front Panel Replacement, Front Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Harman Kardon Onyx Studio 2 Front Panel Replacement, Front Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Harman Kardon Onyx Studio 2 Front Panel Replacement, Front Panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a plastic opening tool, pry off the front grill by wedging it in the notch on the front of the device.
    Where can I find a new front panel for my speaker
    consomme69 - crwdns2934203:0crwdne2934203:0
    If I take this off can I put it back on
    Burger King - crwdns2934203:0crwdne2934203:0
  2. Harman Kardon Onyx Studio 2 Front Panel Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Harman Kardon Onyx Studio 2 Front Panel Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the five 14.4 mm T10 Torx screws.
    There are NO torxscrews. You have to pull out the rubber grille grips that are inside the screw holes FIRST, then use a regular sized Phillips head screwdriver to remove the cover. No Torxscrewdiver needed. I found this out after I had already purchased one from you guys.
    phillip columbus - crwdns2934203:0crwdne2934203:0
    Mi bocina no tiene los 5 tornillos a la vista,tiene las cavidades ciegas, como lo abro???
    Eduardo Heine - crwdns2934203:0crwdne2934203:0
    Yes there are no Torx screws… you have to remove the rubber grips them the Philip Screws..
    Joe Lim - crwdns2934203:0crwdne2934203:0
  3. Harman Kardon Onyx Studio 2 Front Panel Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull the front apart from the back.
  4. Harman Kardon Onyx Studio 2 Front Panel Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Harman Kardon Onyx Studio 2 Front Panel Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four wires connecting the front and back panels.
    • Pinch the connector tab and pull gently upwards.
    • Repeat for the other three connectors.
    Please can I get a replacement of my panel to the phone
    Chinedu Ogunedo - crwdns2934203:0crwdne2934203:0
To reassemble, follow these steps in reverse order.
Alexandra Achtenberg
crwdns2935283:002/02/17crwdne2935283:0
2 096 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 16-5, Blackwell Spring 2017 crwdns2935289:0USF Tampa, Team 16-5, Blackwell Spring 2017crwdne2935289:0
USFT-BLACKWELL-S17S16G5
Hi, I have the ONYX STUDIO with the silver ring that serves as the stand and the handle at the same time. After removing the front grill, I find the same five holes as it is shown on your pics but there are no screws. I can just see a bottom made of plastic. Do you have experience with that? Is that just some cover I can get thru using a screwdriver and I find the screws beneath?
I want to look inside as I am facing the problem with not working battery. As soon as I unplug the power source, it stops working.
Thank you for your comments.
Vaclav Matoulek - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 41
crwdns2942667:0crwdne2942667:0 6,629
