Harman Kardon Onyx Studio 2 Circuit Board Replacement
  1. Harman Kardon Onyx Studio 2 Circuit Board Replacement, Front Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Harman Kardon Onyx Studio 2 Circuit Board Replacement, Front Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Harman Kardon Onyx Studio 2 Circuit Board Replacement, Front Panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a plastic opening tool, pry off the front grill by wedging it in the notch on the front of the device.
    Where can I find a new front panel for my speaker
    consomme69 - crwdns2934203:0crwdne2934203:0
    If I take this off can I put it back on
    Burger King - crwdns2934203:0crwdne2934203:0
  2. Harman Kardon Onyx Studio 2 Circuit Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Harman Kardon Onyx Studio 2 Circuit Board Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the five 14.4 mm T10 Torx screws.
    There are NO torxscrews. You have to pull out the rubber grille grips that are inside the screw holes FIRST, then use a regular sized Phillips head screwdriver to remove the cover. No Torxscrewdiver needed. I found this out after I had already purchased one from you guys.
    phillip columbus - crwdns2934203:0crwdne2934203:0
    Mi bocina no tiene los 5 tornillos a la vista,tiene las cavidades ciegas, como lo abro???
    Eduardo Heine - crwdns2934203:0crwdne2934203:0
    Yes there are no Torx screws… you have to remove the rubber grips them the Philip Screws..
    Joe Lim - crwdns2934203:0crwdne2934203:0
  3. Harman Kardon Onyx Studio 2 Circuit Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull the front apart from the back.
  4. Harman Kardon Onyx Studio 2 Circuit Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Harman Kardon Onyx Studio 2 Circuit Board Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four wires connecting the front and back panels.
    • Pinch the connector tab and pull gently upwards.
    • Repeat for the other three connectors.
    Please can I get a replacement of my panel to the phone
    Chinedu Ogunedo - crwdns2934203:0crwdne2934203:0
  5. Harman Kardon Onyx Studio 2 Circuit Board Replacement, Control Board: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the silicone button band off of the outer edge of the speaker.
  6. Harman Kardon Onyx Studio 2 Circuit Board Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Harman Kardon Onyx Studio 2 Circuit Board Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the two pressure connections from the circuit board.
  7. Harman Kardon Onyx Studio 2 Circuit Board Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Harman Kardon Onyx Studio 2 Circuit Board Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently remove the control board band by placing fingers in contact with it through the button openings.
    • Work from the outer edges in so as not to bend the band.
    From where to buy Control panel
    ali - crwdns2934203:0crwdne2934203:0
    From where to buy this control panel
    My speakers control board band broke. If possible, where can I find replacement?
    Abraham Lepez - crwdns2934203:0crwdne2934203:0
  8. Harman Kardon Onyx Studio 2 Circuit Board Replacement, Circuit Board: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Harman Kardon Onyx Studio 2 Circuit Board Replacement, Circuit Board: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the remaining connectors from the circuit board.
    • Disconnect the Bluetooth antenna.
  9. Harman Kardon Onyx Studio 2 Circuit Board Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Harman Kardon Onyx Studio 2 Circuit Board Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 10 mm T10 Torx screws.
    • Pull the circuit board out of the device as it is now free.
    I own two of these and the both shut down on their own.. where do I buy the replacement boards from?
    Darren Vincent - crwdns2934203:0crwdne2934203:0
crwdns2935229:011crwdne2935229:0
Alexandra Achtenberg
crwdns2935283:002/02/17crwdne2935283:0
2,081 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 16-5, Blackwell Spring 2017 crwdns2935289:0USF Tampa, Team 16-5, Blackwell Spring 2017crwdne2935289:0
USFT-BLACKWELL-S17S16G5
Umm… this was rather anticlimactic. Last step was basically like “and now contemplate your life choices”.
markcendan - crwdns2934203:0crwdne2934203:0
Where can I Buy a new hk onix studio Main board?
tecnologia en localizaciòn - crwdns2934203:0crwdne2934203:0
My speaker was working great. I just disconnected my phone to make a call, put YouTube back on it was all mumbled & the big button in the back kept pulsing so fast.
Maureen Field - crwdns2934203:0crwdne2934203:0
Donde consigo una placa nueva?
Marcelo Peña - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 75
crwdns2942667:0crwdne2942667:0 22,915
