After removing the control board and circuit board, the Bluetooth antenna can be accessed and therefore removed. This is helpful if a lack of Bluetooth connectivity is due to the speaker.
Using a plastic opening tool, pry off the front grill by wedging it in the notch on the front of the device.
Remove the five 14.4 mm T10 Torx screws.
There are NO torxscrews. You have to pull out the rubber grille grips that are inside the screw holes FIRST, then use a regular sized Phillips head screwdriver to remove the cover. No Torxscrewdiver needed. I found this out after I had already purchased one from you guys.
Mi bocina no tiene los 5 tornillos a la vista,tiene las cavidades ciegas, como lo abro???
Yes there are no Torx screws… you have to remove the rubber grips them the Philip Screws..
Gently pull the front apart from the back.
Remove the four wires connecting the front and back panels.
Pinch the connector tab and pull gently upwards.
Repeat for the other three connectors.
Please can I get a replacement of my panel to the phone
Pull the silicone button band off of the outer edge of the speaker.
Disconnect the two pressure connections from the circuit board.
Gently remove the control board band by placing fingers in contact with it through the button openings.
From where to buy Control panel
From where to buy this control panel
My speakers control board band broke. If possible, where can I find replacement?
Disconnect the remaining connectors from the circuit board.
Disconnect the Bluetooth antenna.
Remove the four 10 mm T10 Torx screws.
Pull the circuit board out of the device as it is now free.
Bisa di kirim
Bisa pesan 1
I own two of these and the both shut down on their own.. where do I buy the replacement boards from?
Using the wide blue plastic opening tool, gently peel back edges of the Bluetooth board.
Peel off completely and remove from the device.
I was wondering if you guys have this bluetooth antenna available for sale.
Thank you
Any idea where we can purchase the replacement parts?
Where can I find a new front panel for my speaker
consomme69 - crwdns2934203:0crwdne2934203:0
If I take this off can I put it back on
Burger King - crwdns2934203:0crwdne2934203:0
