This guide will help you replace the Harman Kardon Esquire Mini speakers. In case the speakers are not working or there is a buzzing sound and you need to replace it, this guide will help you to do so. A plastic opening tool and PH0 screwdriver will be needed to accomplish this guide.
Using the plastic opening tool, to open the back panel of the device. Start on the longer sides to avoid bending the metal frame at the plug ports.
Push down on the plastic opening tool, and push the back panel, repeat this for the 4 sides of the device.
Using the PH0 screw driver, remove the 7.5 mm screws by turning in a counter-clockwise direction. There are 6 screws on the front panel.
Remove all of the 7.5 mm screws, by repeating the same step above. It is not necessary to remove the stand-leg.
After unscrewing the 7.5 mm screws, just lift the plastic and you will see the motherboard.
Pull out the motherboard by removing 4 screws around the perimeter of the motherboard. Keep in mind the wires still attached to the speakers, so pull gently.
Using the PH0 screwdriver unscrew the screws, there is one 4 mm screw on each speaker.
Re-do the same steps above for the other speaker to remove it.
Remove the speaker by using the plastic opening tool. Apply a gentle upward force to remove it.
speaker spec is 4Ohm 2w, 27mm diameter, 12.7mm Hight
Model number is F27N4A , L00010-0001001, 019G, L4G4
Where I can find it? I looked for it on Ali Express but it is no longer available.
You can find it in aliexpress by keyword “ HARMAN 1 inch 4 ohm 4 W woofer speaker” “28mm 2W 4Ohm stereo speaker”
but, must 27mm or 28mm unit. not 30mm or 24mm unit.
there many variations.
purzo -
The speaker it self can be ordered by calling harman kardon. The part number is EB-M02700040100-B
The part number for the speaker is EB-M02700040100-B. You can order it by calling harman
Would this one work?
C$ 2.76 50% Off | Mini 28mm 2W Stereo Audio Speaker 1"inch 4Ohm Full-range DIY Loudspeaker
Could I use 8Ohm instead of 4Ohm
These little Speakers can be repaired without replacing the Speakers. First take out the driver and I use Gorilla glue, tahe the glue and squeeze a little amount on a piece of plastic or cardboard, before applying the glue to the surround, make sure you lift the center up over the tear apply glue the 4 places and readjust the Speaker to make sure it's centered., Wait about 45 to 60 minutes to allow the glue to set up, then using a toothpick apply glue around the entire year, be careful not to use too much glue. Before putting it back together, turn on the Speaker and play music at about half volume and if the voice coil is not rubbing, then in about an hour, re-assemble the Speaker, It will sound great, if y follow my instructions, good luck and if you have any questions please contact me anytime.
crwdns2935229:015crwdne2935229:0
crwdns2947412:039crwdne2947412:0
Where can i buy a new speaker for this sound box ? thanks… sizinojr@gmail.com
Did you ever find the replacement speaker? I need one too.
Thx.
Troy -
Thanks, I need speaker also, where can I buy.
mnyucel@yahoo.com
Hi, I also need to know where could get new replacement speaker.
Thanks
Hi, I also need to know where could I get the replacement speaker.
Thanks
What model of speaker for this sound box? Thank you.
Hi, I also need to know where could I get the new replacement
many thanks, joenora2007@gmail.com
Mine blew out, and my friends blew out too. wtf?
Not impressed with the quality.
So many people trying to fix this sh** !
I just opened mine, it looks like one side overheated and melt the plastic around the speaker.
I can’t find any replacement speaker anywhere on internet.
HK sucks ! Last time I buy anything from them.
Useless post as it doesn’t have proper answers
I also need a speaker. But do not now what analogs or generics may suit.
Ya sounds like we are all having this issue sad this speaker seems to have the same issue.Anyone mention where to find the replacement speaker
Hello;
please Where can i buy the speaker replacement????
varovarovaro@gmail.com
thanks!
I need the replacement speaker for Esquire Mini, please send info to memolimag@gmail.com
Thanks,
nobody found replacement speaker
any luck on the replacement speakers???
Lol…..is anyone running this forum? This is called 'ifixit', but you offer no solutions!!! Very frustrating and misleading.
Please offer solutions…links…referrals…suggestions…how-to videos…anything other than a forum of unanswered comments from legit consumers with a specific, yet common product concern.
I need the replacement speaker for Esquire Mini, please send info: kvkv8282@gmail.com
Thank you.
please send specs woofer? tanks
asus72@hotmail.com
Where to buy the replacement speaker
nikkidoss91@gmail.com
Me too my speaker was broken as well. WTF!! It seems very common deficit for this model
I myself need replacement speaker for Esquire mini please send information on where to order to hartmanl334@gmail.com Thank You!
Also need to know the size of speaker thank you!
I think this is the reference of speaker you are looking for :
i conform to above link replace speaker is same as my broken one.
My chinese isn’t that good. Any chance to get the right speaker reference and the right link to order spare parts?
the 1688 link is a little tricky !
HQ ESQUIRE Mini Speaker =
Seems to be a big flaw in this methodology -the wire attached to the left speaker loops through the circuit board via the speaker hole and is soldered to the top of the circuit board. This prevents the circuit board from being moved more than a couple of mm as the wire has no play in it.
I have searched the internet and I still can't find the spare part, there is no part number either, is it true that it is 27mm? could someone help?
Anyone ever find replacement speakers for the harman/kardon Esquire mini?
Thanks
martincenovi@hotmail.com
Please kindly advise where I could buy the replacement speaker
Thanks
raylohw@gmail.com
Not exactly the same but it works.
Does it have the same quality?
Where can i buy a new speaker for this esq mini?
Hi all,
I have an Esquire Mini with blown speakers as well, it took me half a day of looking around the World Wide Web and I can say, I finally found it, it is from China as anything else would be, but it’s cheap in comparison to a new Esquire Mini. Feel free to email me if the link does not work properly. @ viktorval@gmail.com
And without further a due…. Drumroll please….
shorturl.at/mpNY6
Where I can buy the speakers
gourisankarp82@gmail.com
hi
where I can find the replace speaker
and what is speaker no or volt
Hi Everyone!
For those looking for the replacement speaker, it would be under part # EB-M02700040100-B and you can only order from Harman Kardon directly. I think it is about 15-20 dollars each plus shipping.
