This guide will show how to remove the old spark plugs, check the new spark plugs for installation, prepare the spark plugs for installation, and reinstall the new spark plugs.
The spark plugs are easy to spot on the left side of the motorcycle.
Carefully remove the spark plug wire. Do not pull on just the wire, squeeze the spark plug boot, and pull it together with the wire.
Use an 11/16" spark plug socket to unscrew the spark plug by turning in a counter-clockwise direction.
Remove the spark plug from the cylinder.
Always inspect your new spark plugs before installing. Check the gap on your replacement spark plugs with a feeler gauge. It should be set to .040 inches (1.016mm).
Pro tip, add some anti seize compound to the plug threads or the plugs may seize in the cylinder head next time you remove them.
Using your fingers, install the new spark plug into the socket, and hand tighten until firm.
Using a torque wrench, tighten the spark plug to the proper specification.
Questions.1 with a stage 1,2 or 3 would you agree a wider gap? 2nd question which is simular to first.i do run my motor a little rich.rather rich than lean.my question is with modification on a harley davidson sportster.what do ou recommend.so many choices from om to iridium to platinum.then the gap and also are you a believer in cutting the eledtrode approx half off for max combustion.how much would you recommend cutting and back to og question.the gap.is a larger gap.capable of power increase.since ive tried both i swear i feel a power increase.but is it anticipated or other varibles???you opinion is valued.
So do u recmciameme. A 50 gap other over 3o mm over a50 mm gat over a 50 nun
I'm going to ask you what the hell is going what is a proper sport club gap on a 2000 model 883c
I've changed the carburetor and get a tune up on it it was running fine now all of a sudden it acts like it's not getting any Spark or very little
Holle I'm still her waiting
What do you want me to reply I've explained everything the best I could
Rusty m -
Reinstall your spark plug wire by pushing it firmly onto the new plug.
I have a Harley Davidson Xr1200x Sportster which I just got. Changed the oil also tranny & filter as I couldn't find last date of service coang of oil. So yesterday I checked the spark plugs they were clean. But the mechanic cleaned them & said the needed gap them as one was too narrow. Mind you I had no issues at all. Gapped them at 0.40 now I'm not getting the same smooth sound or feel as if it's miss firing. I have iridium spark plugs okn my bike should I change them to NGK or get another set of iridium spark plugs.please advise..
A spark plug Gap is to be checked with a wire feeler gauge, not a flat feeler gauge….
Which wires go to which plug
Be sure to repeat the above procedure for the remaining cylinder.
crwdns2935229:021crwdne2935229:0
crwdns2947412:08crwdne2947412:0
Just for information, particularly in the UK, you may be able to purchase sparking plugs cheaper at a Chandlers, as there are quite a few 4-stroke outboard engines use these plugs.
How do you do this with a XL1200S with dual spark plug heads??
Couldn't have made it any simpler
-awesome
- appreciated
Thank you so much for your posting. I'm 2k miles from my daughter who is teaching herself how to maintain her own bike. You site is immensely helpful and appreciated as much.
Says between 11 and 18 pounds in manuel
Is there a firing order like on a car I'm just trying to make sure I have the rite plug with the rite plug wire
I really appreciate your site…thank you.
Can anyone tell me if a 1999 sporster has a data link connector port . my bike would not start the coil was bad replaced it now no spark at all can anyone help
