Hamilton Beach 25460Z Bottom Heating Element Solders Replacement
  1. Hamilton Beach 25460Z Bottom Heating Element Solders Replacement, Plug Wiring: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hamilton Beach 25460Z Bottom Heating Element Solders Replacement, Plug Wiring: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug your device before proceeding with disassembly.
    • Remove the four 14mm screws from the bottom of the Panini Press using the T10 Screwdriver.
  2. Hamilton Beach 25460Z Bottom Heating Element Solders Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up the plastic cover to expose the plug wiring.
    • Mark the plug wire connected to the red wire with a piece of tape. This will be used as a reference for reassembly.
    it doesn't matter red or blue it's just AC power
    Qatra - crwdns2934203:0crwdne2934203:0
  3. Hamilton Beach 25460Z Bottom Heating Element Solders Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hamilton Beach 25460Z Bottom Heating Element Solders Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hamilton Beach 25460Z Bottom Heating Element Solders Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the pliers to pinch the widest point of the cap. This should be done opposite of the already existing crimps.
    • Slide off the white cap.
    • Repeat these steps for the second white cap.
  4. Hamilton Beach 25460Z Bottom Heating Element Solders Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hamilton Beach 25460Z Bottom Heating Element Solders Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two rubber screw covers from the bottom of the Panini Press.
    • Remove the four uncovered 10mm screws with the PH2 Screwdriver.
  5. Hamilton Beach 25460Z Bottom Heating Element Solders Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hamilton Beach 25460Z Bottom Heating Element Solders Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the plastic lower heating element up and place to the side for reassembly. You have now disconnected the plug wiring completely.
  6. Hamilton Beach 25460Z Bottom Heating Element Solders Replacement, Bottom Heating Element Solders: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hamilton Beach 25460Z Bottom Heating Element Solders Replacement, Bottom Heating Element Solders: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the PH2 screwdriver and a bit of force, remove the two 10mm screws holding the thermal switch to the cooking surface.
    • These screws may be difficult to remove.
  7. Hamilton Beach 25460Z Bottom Heating Element Solders Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the PH2 screwdriver, remove the single 10mm screw connecting the red wiring cover to the cooking surface.
  8. Hamilton Beach 25460Z Bottom Heating Element Solders Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now pull both the thermal switch and the red wire to the back of the press, allowing easier access to the heating element leads.
    • Replace the missing solder.
    • The left lead, marked with a red circle, is connected to 2 white wires.
    • The right lead, marked with a yellow circle, is connected to 2 red wires.
    Don't hold the soldering iron like that- you'll burn your fingers !!
    Chris Bircham - crwdns2934203:0crwdne2934203:0
Forrest Rodeman
crwdns2935283:002/01/15crwdne2935283:0
327 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 6-27, Amido Winter 2015 crwdns2935289:0Cal Poly, Team 6-27, Amido Winter 2015crwdne2935289:0
CPSU-AMIDO-W15S6G27
Muy detallado, era aproximadamente lo que buscaba.
Hay posibilidades de que sea en los pasos a seguir, sean en Español. De ser así podría resolver el problema, gracias
alcides torres lopez - crwdns2934203:0crwdne2934203:0
Estoy tratando de resolver la avería de mo Sandwichera Hamilton Beach modelo 25460Z, desde mi hogar y desearía que la respuesta fuera en idioma Español, gracias
crwdns2942667:0crwdne2942667:0 3,319
