HTC Vive Sensor Array Replacement
crwdns2942287:0crwdne2942287:0Use this guide to remove and replace the sensor array in an HTC Vive.
You'll need a narrow, long-shaft driver to reach some of the screws in this guide.
crwdns2944105:0crwdne2944105:0
Place a finger on the top edge of the compartment cover assembly and slide the assembly toward the front of the Vive until it comes loose from the headset.
Lift the cover away from the headset and slide it up the cables until it's out of the way.
Lift the HDMI cable straight up to unplug it from the headset.
Repeat the lifting and unplugging process with the remaining USB, power, and audio cables.
Use a T5 Torx driver to remove the two 12 mm-long screws securing the head strap mounts on either side of the headset.
Remove both head strap mounts.
Slide the facerest straight away from the headset to remove it.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use tweezers to remove the small stickers over the four screws securing the outer shell.
Use a T5 Torx driver to remove the four 3.4 mm-long screws securing the outer shell.
Grasp the top edge of the right half of the outer shell, behind the component cover and near the seam in the center. Pull it to the right and upward, away from the headset to release the clip securing that part of the shell.
Grasp the right half the outer shell and pull it to the right and toward the front of the headset in a twisting motion until you feel the clips on the front of the cover release.
Slide the right side of the outer shell to the right and off of the headset.
Repeat the last three steps for the left side of the outer shell and remove it.
Use tweezers to remove the clear tape over all four of the sensor array cable connectors.
Use the pointed end of a spudger to flip up the small locking flap on one of the sensor array ZIF connectors.
Slide the cable straight out of its socket on the motherboard.
Repeat the previous step for the remaining three sensor array cables to disconnect the remaining cables.
Use tweezers or a spudger to pry up the camera cable cover and remove it.
Use the flat end of a spudger to pry the camera cable connector straight up from its socket on the motherboard.
Use a PH000 driver to remove the five 3.9 mm screws securing the sensor array.
Use a PH000 driver to remove the four 3.9 mm screws securing the sensor array.
crwdns2935267:0crwdne2935267:0Phillips #000 Screwdriver$5.49
Lift the sensor array away from the headset to remove it.
Herzlichen Dank für diese ausführliche Anleitung! Sie war sehr hilfreich und hat mir vermutlich eine Menge Zeit erspart!
