The disassembly of the HTC Vive Cosmos is provided.
Static Warning for circuit board interaction. When dealing with jumper cables and circuit boards touch metal not located on Vive for 15 seconds before removing component.
Peel back the interchangeable foam velcroed to the headset.
Hold the button on the inside of the headset.
Pull back the frontplate away from the Vive.
Peel the two warranty stickers using a driver.
Unscrew nineteen screws using the T5 Torx driver.
Remove the covers beneath the warranty stickers.
Insert card between plate and camera plate to separate and remove.
Unscrew the three torx screws using the T5 X 50 mm screwdriver.
Unscrew the one Philips screw using the 10 mm screwdriver.
Detach headband from headset.
Insert card between camera plate and the headset to separate.
Slide the focus knob out of the plastic holding and off the focus rod.
Unplug the jumper cables from the circuit boards to detach.
Unscrew the four silver Torx screws on the jumper cables using the T5 driver.
Pull the jumper cables away from the holding and remove.
Unscrew the nine Torx screws using the T5 driver on the circuit board.
Remove the jumper cables to fully release the cable port board.
Unscrew the six Torx Screws on the camera board with the T5 driver.
Unscrew the one Torx Screw using the T5 driver.
Pull and maneuver the heat duct out of the holding.
Unplug the fan from the camera board.
Insert screwdriver beneath strip plug to remove.
Lift camera board and remove.
Thanks for not mentioning the microphone and the fact that you also tore yours doing the disassembly! Will you replace the mic that was working before i took it apart to repair other issues? No? Exactly. Don't do any more guides and people: find a better one. Moron.
