A guide to replace the screen in your HTC Touch Pro CDMA phone.
Remove the back cover (not pictured) to your phone.
To remove the battery, place your thumb beneath the tab and begin to lift.
Pinching the battery, lift up at an angle from the bottom of the phone.
Use a T6 screwdriver to remove the four screws on the rear plate of the HTC Touch Pro.
Next, remove the casing that covers the camera and motherboard.
Insert your spudger along the slit between the keyboard and the external casing. Pry open as shown.
Remove the keyboard ribbon from the motherboard. To do this, simply grasp the ribbon at its base and pry it up at an angle. The ribbon has a metal end that is easily removed from the motherboard.
Using a Phillips Head size 0 screwdriver, remove the 3 screws holding in the battery compartment.
Remove the ribbon covering the battery compartment by pinching it at the base and lifting.
Move the black slider over to the side without the keyboard ribbon. This is done as to allow the display ribbon to slide out later.
Using a PH 0 screwdriver, remove the 4 screws on the black slider.
Pry the keyboard away from the screen. Open on the side containing the keyboard ribbon.
Remove the four screws on the back of the screen assembly using the PH #0 screwdriver.
Pry the rear of the screen assembly off from the side opposite to the display ribbon using the spudger
Remove the connected circuit board components behind the phone's navigation buttons.
Remove the four circuit board screws using the PH #0 screwdriver
Push on the back of the board gently to remove the navigation buttons on the front.
Flip the phone to the front and remove the four screws holding the circuit board to the phone frame using the PH #0 screwdriver.
Remove the two screws at the top of the screen using the PH #0 screwdriver.
Remove the beige piece after the screws have been removed as shown.
Push gently on the back of the screen to release the glue holding it to the phone frame.
Peel the screen from the frame to completely separate the two components.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
