HTC Sensation Touchscreen/Digitzer Replacement
  1. HTC Sensation Touchscreen/Digitzer Replacement, Broken Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC Sensation Touchscreen/Digitzer Replacement, Broken Screen: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC Sensation Touchscreen/Digitzer Replacement, Broken Screen: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • DO NOT pry loose as shown in this picture. The button in the middle that is pictured can be pressed in, releasing the back housing which can then be easily lifted free.
    What?! You just press the button and it comes apart. DON'T pry anything apart or you'll probably break the mechanism that keeps the cover on!
    Chris Emerson - crwdns2934203:0crwdne2934203:0
    I would like to point out that with a lot of smartphones these days, there isn't a button you can push that will simply pop off the back casing. Anymore, you NEED pry tools to remove these things, because the mechanism holding them there is a simple hook that clicks into place. It's all a solid piece, but you can normally remove back casings without doing damage to the phone. The manufacturers will typically have an area on the phone where you can pry from without causing damage, and if you do it slowly, carefully, and gently, you should have no problems.
    You are absolutely correct that, in the event there IS a button that holds the case in place, you absolutely should have it depressed, but the button in this picture looks like a power button or something similar, making your point irrelevant.
    saiyashamisamurai1 -
    I tried editing this step, but it wouldn't let me. As Chris says, DON'T pry off the back housing. It will break your phone! Some of these are tricky, as mine doesn't always lift off easily regardless of whether or not I press the bottom button. At the most, with the button depressed, put something like a guitar pick or similar in the seam and use that to help you lift off the back, but make sure the button is pressed down!
    Chad McCollister - crwdns2934203:0crwdne2934203:0
  2. HTC Sensation Touchscreen/Digitzer Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC Sensation Touchscreen/Digitzer Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC Sensation Touchscreen/Digitzer Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the battery, SIM card and SD card.
  3. HTC Sensation Touchscreen/Digitzer Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Torx screwdriver, remove the 6 screws show in the photo.
  4. HTC Sensation Touchscreen/Digitzer Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC Sensation Touchscreen/Digitzer Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC Sensation Touchscreen/Digitzer Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a plastic pry tool, at the top, the right and left sides and the bottom, carefully insert and pry to pop loose the plastic frame from the LCD/Touchscreen Housing.
  5. HTC Sensation Touchscreen/Digitzer Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the one Phillips head screw from the motherboard.
    • Remove the silver tape/adhesive covering 2 jawbone connectors.
  6. HTC Sensation Touchscreen/Digitzer Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully disconnect the 2 jawbone connections.
    • Be careful to open the connectors the correct way or they will break, ruining your phone!
  7. HTC Sensation Touchscreen/Digitzer Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Sensation Touchscreen/Digitzer Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the black plastic covering the volume buttons on the side.
  8. HTC Sensation Touchscreen/Digitzer Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC Sensation Touchscreen/Digitzer Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC Sensation Touchscreen/Digitzer Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the same black plastic from the top power button. Be careful to only remove the plastic as there is a flex cable under.
    • Go ahead and carefully pull the power button flex up.
  9. HTC Sensation Touchscreen/Digitzer Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC Sensation Touchscreen/Digitzer Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC Sensation Touchscreen/Digitzer Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the power button flex up you can now carefully pull up the motherboard.
    • BE CAREFUL as there are still two cables connected to jawbone connectors on the underside of the motherboard.
    • On the underside you will barely see the jawbone connectors. Go ahead and flip them open to release the cables.
  10. HTC Sensation Touchscreen/Digitzer Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Sensation Touchscreen/Digitzer Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before lifting up the motherboard, be sure to release the 2nd jawbone connector. This one is for the touchscreen/digitizer. (Photo is with motherboard already out to show you exactly where it is.
    • With the flex cable removed you can now lift up on the motherboard. There is still a cable attached, but it is the touchscreen/digitizer cable. So, if you have a broken screen it IS ok if you break this cable.
  11. HTC Sensation Touchscreen/Digitzer Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Sensation Touchscreen/Digitzer Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now can you completely remove the motherboard.
    • There are little "teeth" around the mother board so if you are having some trouble it's because the motherboard is still caught under the teeth.
  12. HTC Sensation Touchscreen/Digitzer Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Sensation Touchscreen/Digitzer Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a heat gun, carefully heat the glass all around the screen. Be careful not to overheat as this can cause damage to the LCD.
  13. HTC Sensation Touchscreen/Digitzer Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC Sensation Touchscreen/Digitzer Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC Sensation Touchscreen/Digitzer Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Starting at the top and then going down the sides, carefully insert a plastic pry too and begin to separate the touchscreen glass from the LCD assembly.
    • Be careful as you get to the bottom when removing the glass. There is a thin strip that needs to stay in tact.
    • When at the bottom you will notice a white strip. Do not tear this or the buttons on the bottom of your screen will not light up!
    • Go ahead and remove the glass completely.
  14. HTC Sensation Touchscreen/Digitzer Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Sensation Touchscreen/Digitzer Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Microfiber Cleaning Cloths
    $3.99
    • Remove the top layer of sticky black tape, then prep the LCD assembly and new touchscreen/digitizer with new adhesive--I just used thin strips of two-sided tape.
    • Using a microfiber cloth remove any dust from the LCD display.
    • Slide the new touchscreen/digitizer cable between the frame and LCD display.
    • Be VERY careful with the touchscreen/digitizer cable! If needed, it is ok to lightly and carefully push against the backside of the LCD to create more space. You may need to pull the cable through forcefully; just don't rip it or break the LCD.
    • Once the cable is through go ahead and remove all paper from adhesives and set the screen in place.
    • Now you can begin reconstructing your phone. Go ahead and go through the steps backwards.
    • Reattaching the cables is the trickiest part but not impossible.
crwdns2935229:029crwdne2935229:0
Brent Huff
crwdns2935283:004/24/12crwdne2935283:0
2.058 crwdns2915208:0crwdne2915208:0
Hello, good afternoon!
I wonder what the material used between the screen and the lcd display?
I realized that there is a sort of black film behind the touch screen. What would it be?
Jean Carlos
Jean Silva - crwdns2934203:0crwdne2934203:0
Be extremely careful when removing old digitizer out of frame & when placing a new one! I have broken my LCD because of the pressure I applied to the screen.
maxmalysh - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 60,224
