HTC Radar 4G Battery Replacement
  1. HTC Radar 4G Battery Replacement, Slide off the back panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Radar 4G Battery Replacement, Slide off the back panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide off the white back panel.
    • This is the time to remove the SIM card, so remove it now.
  2. HTC Radar 4G Battery Replacement, Remove the motherboard protector screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 4 silver T5 Torx screws from the motherboard protector.
    • Some screws may be stuck in. If so, use a pair of tweezers to carefully remove them from their holes.
  3. HTC Radar 4G Battery Replacement, Slide off the rear motherboard protector: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully slide off the motherboard protector.
    • This may take some force if this is the first time opening the phone.
    • Take care not to apply too much downward force, because you may accidentally damage the sensitive components on the motherboard.
  4. HTC Radar 4G Battery Replacement, Remove the frame screws: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 2 black T5 Torx screws from the silver frame.
    • Make sure to not accidentally slip the screwdriver, because you may break sensitive components on the motherboard.
  5. HTC Radar 4G Battery Replacement, Remove the casing: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently push on the motherboard until the display starts to come out of its frame.
    • Once it is at about a 30-degree angle, grab the display and pull it downwards to remove it from the frame.
    • Remember, do this carefully. We don't want to end up with a dead motherboard.
  6. HTC Radar 4G Battery Replacement, Remove the battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    iFixit Opening Picks (Set of 6)
    • Use a fingernail or an opening pick to lift the battery out of its slot.
    • Insert the opening pick on the right side at the top for best results.
    • Once it is at about a 30-degree angle, pull up on the battery to disconnect it.
To reassemble your device, follow these instructions in reverse order. Calibrate your new battery for optimal performance.Take your e-waste to an R2 or e-Stewards certified recycler.
hellonearth311
crwdns2935283:003/30/24crwdne2935283:0
390 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 197
