HP rp5700 Cover Removal Replacement
  1. HP rp5700 Cover Removal Replacement, Cover Removal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure the computer is unplugged.
    • Be sure to touch any metal surface with your hand to discharge any static electricity that might have built up.
    • Make sure all auxiliary cords are disconnected from the desktop. If not, remove them using your hands.
    • Set the desktop down horizontally with the front side facing you.
  2. HP rp5700 Cover Removal Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP rp5700 Cover Removal Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Hold the desktop with two hands by grasping both sides of the desktop.
    • Press the buttons on both sides using your index fingers.
    That not work for me I push both botton but nothing move it out. Thank. May be it necessary another hand
    Revnunez - crwdns2934203:0crwdne2934203:0
  3. HP rp5700 Cover Removal Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP rp5700 Cover Removal Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP rp5700 Cover Removal Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the top cover about an inch forward using your thumb to push it towards you.
    • Make sure that the bottom is still secured by both hands.
    • Lay the desktop back on the table and pull the case forward as far as it can go.
    • Lift the cover up and off.
    In this step, make clear that the CPU is lifted in the air to aide in the cover separation. Cover removal for a CPU is usually the most time consuming step if not clearly outlined. Employ brevity but clarity.
    Mark - crwdns2934203:0crwdne2934203:0
crwdns2935229:011crwdne2935229:0
Alyssa Briones
crwdns2935283:001/21/14crwdne2935283:0
1.720 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 6-23, Maness Winter 2014 crwdns2935289:0Cal Poly, Team 6-23, Maness Winter 2014crwdne2935289:0
CPSU-MANESS-W14S6G23
Thank you! It's easy once you know how to do it, but I was stumped trying to figure it out.
John Evans - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 90
crwdns2942667:0crwdne2942667:0 22,921
