HP ZBook 15 Hard Drive Replacement
  1. HP ZBook 15 Hard Drive Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP ZBook 15 Hard Drive Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the laptop over.
    • Slide the lever with the battery symbol beside it firmly until the battery pops out.
    • Remove the battery from the laptop.
  2. HP ZBook 15 Hard Drive Replacement, Back Cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the right lever firmly to the right.
    • Slide the cover towards yourself to remove it.
  3. HP ZBook 15 Hard Drive Replacement, HP ZBook 15 Hard Drive Disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the three captive screws holding the drive in place with a Phillips #0 screwdriver.
    • The screws will remain inside the springs of the hard drive caddy cover.
  4. HP ZBook 15 Hard Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP ZBook 15 Hard Drive Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the green tab away from the metal casing and lift the drive out.
  5. HP ZBook 15 Hard Drive Replacement, Hard Drive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 3mm screws on either side of the device with a Phillips #0 screwdriver to remove the drive caddy.
crwdns2935229:013crwdne2935229:0
Grant Terris
crwdns2935283:001/30/15crwdne2935283:0
2,849 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 8-43, Amido Winter 2015 crwdns2935289:0Cal Poly, Team 8-43, Amido Winter 2015crwdne2935289:0
CPSU-AMIDO-W15S8G43
You can use Macrium Reflect (there's a free non-commercial version) to backup your disk to an external drive before swapping the drive.
Paul M - crwdns2934203:0crwdne2934203:0
There is written 'SSD' on its cover, and I'm confused now. Actually I need to disconnect the HDD and then install new OS on the SSD, and now I'm not sure if the drive that you just removed is SSD or HDD because on mine it say SSD. Please help me out.
Sajid - crwdns2934203:0crwdne2934203:0
how hard disk i can buy for my zbook 15?
thanks
francesco perego - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 94
crwdns2942667:0crwdne2942667:0 30,397
