Use this guide to replace the digitizer control board.
In the following steps, you will use a metal spudger to lift the front panel out from the rear case of your TouchPad.
Insert a flat metal spudger in the gap between the rubber outer ring on the front panel assembly and the black plastic rear case near the USB connector.
Pry the front panel assembly up from the rear case, being careful not to damage the LCD or the glass panel.
As in the previous step, use a spudger to pry the front panel up from the rear case along its long edge on the volume button side of the TouchPad.
Continue to pry the front panel assembly up along the volume button side of the TouchPad until there is a gap between it and the rear case.
Pry up the front panel assembly along the top edge of the TouchPad.
Pry up the front panel along the edge closest to the home screen button.
Before lifting the free side of the front panel up from the rear case, you may need to release it from the plastic retaining clips holding it down.
Use your metal spudger to pull the stuck retaining clips away from the edge of the front panel.
After freeing the retaining clips, lift the front panel assembly away from the rear case.
Use the attached black tab to pull the display data cable straight up and out of its socket on the motherboard.
The ribbon can be adhered to other parts placed under it. You'll have to separate them tighly so you don't damage the ribbon.
Use your fingernail to carefully flip up the retaining flaps on the two digitizer ribbon cable ZIF sockets.
Pull the digitizer ribbon cable straight out of its two sockets on the motherboard.
Remove the front panel assembly from the rear case assembly.
Remove the two 3.0 mm Phillips screws securing the digitizer control board to the rear case.
Lift, but do not remove, the digitizer control board out of the rear case.
Using the edge of a plastic opening tool or your fingernail, carefully flip up the retaining flap on the digitizer control board ribbon cable ZIF socket.
Pull the digitizer control board ribbon cable straight out of its socket on the digitizer control board.
Remove the digitizer control board from the TouchPad.
anyone know where to get parts for these things?
Ebay - search for "HP Digitizer"
Where can you buy the piece
when my charger falled on the screen of my hp touchpad its screen did not break but its touchscreen is not working so which part i whant to change
Beware of the ribbon cable right beneath the volume rocker, as it's easy to shear that cable if you are too rough with the metal spudger.
Michael Innes - crwdns2934203:0crwdne2934203:0
I wasn’t happy with using a metal spudger as it felt a bit forceful, as I have a bulk pack of opening tools I tried using them instead.
I may have been lucky, but by using those tools instead with the angled lip facing inwards at points adjacent to where the mounting clips are located according to the above image (like this, https://i.imgur.com/dylp6BG.jpg ), I managed to open the unit without breaking a clip or scratching the plastic back panel by bending the outside of the panel enough to pop the lcd panel.
Michael Sim - crwdns2934203:0crwdne2934203:0
