HP Stream 11-y010nr Trackpad Replacement
  1. HP Stream 11-y010nr Trackpad Replacement, Keyboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Stream 11-y010nr Trackpad Replacement, Keyboard: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Stream 11-y010nr Trackpad Replacement, Keyboard: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently peel back the two rubber strips that cover the screws on backside of the computer with the needle nose tweezers.
    • Ensure the laptop is turned off.
  2. HP Stream 11-y010nr Trackpad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Stream 11-y010nr Trackpad Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the seven 0.4mm screws on the backside of the laptop with the Phillips #0 Screwdriver.
  3. HP Stream 11-y010nr Trackpad Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Stream 11-y010nr Trackpad Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Take the opening picks and push them into the seam between the keyboard and the laptop casing.
    • Go all the way around the laptop.
  4. HP Stream 11-y010nr Trackpad Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the cover is loose enough, lift the keyboard up to expose the wiring beneath.
    • Be careful not to pull too hard or fast as there are ribbon cables attached to the keyboard and trackpad.
  5. HP Stream 11-y010nr Trackpad Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Stream 11-y010nr Trackpad Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Stream 11-y010nr Trackpad Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the three cables by lifting up on the locking tab of the ZIF connector and pulling the cables out with the needle nose tweezers.
    • Remove the keyboard.
  6. HP Stream 11-y010nr Trackpad Replacement, Trackpad: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Stream 11-y010nr Trackpad Replacement, Trackpad: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Take the keyboard and flip it over. It will look like the pictures.
    • Use the needle nose tweezer to take off protective tape covering the top left and top right screws.
  7. HP Stream 11-y010nr Trackpad Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Stream 11-y010nr Trackpad Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Stream 11-y010nr Trackpad Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the three 0.2mm top screws with the Phillips #00 Screwdriver.
  8. HP Stream 11-y010nr Trackpad Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Stream 11-y010nr Trackpad Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Stream 11-y010nr Trackpad Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the three 0.3mm screws holding the bottom bracket with the Phillips #00 Screwdriver.
  9. HP Stream 11-y010nr Trackpad Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Stream 11-y010nr Trackpad Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Stream 11-y010nr Trackpad Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift up on the bracket and remove the bracket by lifting up on the metal end as shown.
  10. HP Stream 11-y010nr Trackpad Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Stream 11-y010nr Trackpad Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Stream 11-y010nr Trackpad Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The trackpad is now free to be removed.
    • Remove the trackpad by gently pulling up on the metal piece on the bottom left corner of the trackpad.
To reassemble your device, follow these instructions.
Adam Sitzmann
crwdns2935283:001/26/20crwdne2935283:0
932 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S5-G6, Watkins Spring 2020 crwdns2935289:0Embry-Riddle Aeronautical University, Team S5-G6, Watkins Spring 2020crwdne2935289:0
ERAU-WATKINS-S20S5G6
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 352
