HP Star Wars Special Edition 15-an051dx RAM Replacement
  1. HP Star Wars Special Edition 15-an051dx RAM Replacement, RAM: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Star Wars Special Edition 15-an051dx RAM Replacement, RAM: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Star Wars Special Edition 15-an051dx RAM Replacement, RAM: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Make sure the laptop is fully shut down
    • Remove battery by pushing slide tabs to the left.
    • Remove residual power by holding the power button down for 5 seconds.
  2. HP Star Wars Special Edition 15-an051dx RAM Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Star Wars Special Edition 15-an051dx RAM Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Star Wars Special Edition 15-an051dx RAM Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Set aside any screws removed separately as to not mix them up
    • Use a Phillips #1 screwdriver to remove the two 12.5 mm screws, four 5.5 mm screws, and six 7.25 mm screws.
    • Remove the two corner panels along the ends of the battery slot and this will expose another set of screws (1 under each panel).
    • Remove the remaining six 7.2 mm Phillips #1 screws hidden in the battery area and underneath the covers.
  3. HP Star Wars Special Edition 15-an051dx RAM Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Star Wars Special Edition 15-an051dx RAM Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Star Wars Special Edition 15-an051dx RAM Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the optical drive by pulling on the plastic cover panel.
    • With a prying tool, gently pry the back panel off.
    • Start with the corners of the device and carefully slide the tool towards the middle, lifting the panel off as you go.
    • Set the optical drive and back panel somewhere safe.
  4. HP Star Wars Special Edition 15-an051dx RAM Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Star Wars Special Edition 15-an051dx RAM Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Star Wars Special Edition 15-an051dx RAM Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • You will need to spread the two silver clips that hold the RAM down on its slot.
    • Once both clips are spread apart, this will release the RAM and it will slightly spring upward in an angle.
    • Pull the RAM away in the same orientation.
    • Keep in mind the notch on the RAM that connects on to the DIMM slot.
  5. HP Star Wars Special Edition 15-an051dx RAM Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Star Wars Special Edition 15-an051dx RAM Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Star Wars Special Edition 15-an051dx RAM Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Match the notch on new/replacement RAM and gently install it in the same angled orientation.
    • Once the new RAM is installed, gently press and lay the RAM down on its side until it reaches the clips on the side notches and locks in.
    • Do the same for the other DIMM/RAM if replacing or adding another RAM.
Fernando Mendez
crwdns2935283:008/25/22crwdne2935283:0
643 crwdns2915208:0crwdne2915208:0
Gateway, Team 1-2, Pee Fall 2022 crwdns2935289:0Gateway, Team 1-2, Pee Fall 2022crwdne2935289:0
GCC-PEE-F22S1G2
Awesome job. this is a nice guide
RETRO GAMEHEAD - crwdns2934203:0crwdne2934203:0
If you could post another guide on how to clean the fans and heatsink and rethemopasting. I will look at it give you 30 more points. Thanks
crwdns2942667:0crwdne2942667:0 427
