Locate the four screws at the bottom of the device. (Note that the keyboard attachment is missing from this device.)
Use a Philips head #0 screwdriver to remove each of the screws (Size: 4mm)
Gently wedge the plastic opening tool in between where the display and back panel meet.
Slowly and gently apply force to the plastic opening tool in a downwards motion to loosen the front panel from the back panel.
Rotate the device so that the side is facing up and repeat the previous step for the sides.
Do NOT attempt to wedge the plastic opening tool on the bottom . Once the sides and top are loose you are ready to continue to the next step.
Gently and slowly pull the front and back panel away from each other (in opposite directions). ( Pulling them apart will not separate the two panels)
Only separate the panels by a few inches from each other so that there is room to separate the front and back panel in the next step. Proceed to the next step.
Hold the back panel firmly and pull the front panel upwards to completely separate the front panel from the back panel.
The device is now ready to be repaired or replacements installed.
Use the PH1 screwdriver to remove eleven 4mm Phillips screws.
Unscrew the two 2mm zero insertion force connectors. Slide aside the white wires to properly unscrew.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use a pair of tweezers to pull up the yellow colored display cable connector.
Pull it to the direction of the cable.
this is the most difficult step !! I cant really figure out how to pull out that stuff….looks vey fragile…..need help and with more detailed pics in this step please
Glue is attached at the edges. Apply force to the sides of the tablet. Separate the digitizer from the body of the tablet.
Replace the old screen with a new one.
Hello… How to know if it is the digitizer or the screen that is broken? .. thanks
