HP Spectre x360 15" (15t-ap000) Battery Replacement
  1. HP Spectre x360 15" (15t-ap000) Battery Replacement, Unscrew the back cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Be sure to completely power off and unplug your laptop before you begin your repair. Make sure the laptop is not in standby, sleep, or hibernation mode.
    • Use a T5 driver to remove the following screws securing the back cover:
    • Six 4 mm-long screws
    • Two 7.8 mm-long screws
  2. HP Spectre x360 15" (15t-ap000) Battery Replacement, Loosen the back cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Spectre x360 15" (15t-ap000) Battery Replacement, Loosen the back cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening tool or your fingers to pry up the back cover from the laptop.
    • Plastic clips hold the back cover lightly in place, so you may encounter some resistance.
    • If it feels like there is strong resistance, you may have a model that includes screws under the corner feet. Carefully pry the feet up to make sure they don't have screws.
  3. HP Spectre x360 15" (15t-ap000) Battery Replacement, Remove the back cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Spectre x360 15" (15t-ap000) Battery Replacement, Remove the back cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift and remove the back cover.
    • During reassembly, gently press along the perimeter of the back cover to re-engage the clips.
  4. HP Spectre x360 15" (15t-ap000) Battery Replacement, Disconnect the battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Spectre x360 15" (15t-ap000) Battery Replacement, Disconnect the battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Spectre x360 15" (15t-ap000) Battery Replacement, Disconnect the battery: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry the edges of the battery connector with a spudger to loosen the connector from its motherboard socket.
    • Gently pull the connector parallel to the motherboard to disconnect it.
  5. HP Spectre x360 15" (15t-ap000) Battery Replacement, Remove the battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the five 4.3 mm-long screws securing the battery to the laptop.
  6. HP Spectre x360 15" (15t-ap000) Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Spectre x360 15" (15t-ap000) Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift and remove the battery from the laptop.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Arthur Shi
crwdns2935283:001/03/18crwdne2935283:0
304,680 crwdns2915208:0crwdne2915208:0
crwdns2935297:0689crwdne2935297:0
Staff
crwdns2935297:023,259crwdne2935297:0
I have the same model, but there are screws under the two rear rubber feet. I damaged one of the feet during removal ):
Miguel Medina - crwdns2934203:0crwdne2934203:0
I'm sorry to hear that! I double-checked my laptop, and it doesn't have the two feet. Perhaps there was a hardware update. I'll add a note in the guides.
Arthur Shi -
So the battery shown/listed in the store is a PK03XL but the images (and my laptop) clearly have the PG03XL model which has higher amp hours. Also, the PK0 does not fit.
Karim T - crwdns2934203:0crwdne2934203:0
Hi Karim,
That's correct! The PK03XL battery that's sold in the iFixit store is for the 13" HP Spectre. This guide is written for the 15" HP Spectre.
Arthur Shi -
crwdns2936753:030crwdne2936753:0 62
crwdns2942667:0crwdne2942667:0 8,286
