HP Spectre x2 12-a002dx SSD Replacement
  1. HP Spectre x2 12-a002dx SSD Replacement, Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure the device is powered off and the kick stand is retracted.
    • The HP Spectre should be placed on a flat surface with the keyboard detached.
  2. HP Spectre x2 12-a002dx SSD Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Spectre x2 12-a002dx SSD Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Spectre x2 12-a002dx SSD Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To remove the screen, there is an entire system of clips which need to be undone as well as 4 Phillips M1.5x2.7 screws.
    • The screws should be removed using a Phillips #000 screwdriver. There is a sticker where the laptop attaches to the keyboard.
    • Heat the sticker (if needed) and use fine point tweezers to grip the sticker and remove it.
    Could you please some image of the screws and the tool you used?
    fabio - crwdns2934203:0crwdne2934203:0
    Podrían subir el procedimiento para despegar los clip, ? al parecer viene pegada la pantalla a la carcasa, en ese caso se usaría la pistola de calor o estoy mal ? Al guíen que me guié por favor, agradezco de antemano
    sergio villanueva - crwdns2934203:0crwdne2934203:0
  3. HP Spectre x2 12-a002dx SSD Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Spectre x2 12-a002dx SSD Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Spectre x2 12-a002dx SSD Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the plastic opening tools or insert a spudger to begin unclipping the system.
    • Pry the screen off once all the clips have been unclipped.
    • The screen may shatter if not already shattered (beware of flying glass).
    • This screen will break. There is double tape underneath the frame, which is not listed in here.
  4. HP Spectre x2 12-a002dx SSD Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Spectre x2 12-a002dx SSD Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Spectre x2 12-a002dx SSD Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the connecting cable of the screen and battery. Use a spudger to reveal the adhesive strip and carefully peel it off.
    • Insert a spudger to the other end and release the ZIF connectors. Detach the cable.
    • While a metal spudger is pictured, use a black nylon spudger instead because it is ESD safe.
  5. HP Spectre x2 12-a002dx SSD Replacement, SSD: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once you have successfully removed the screen, locate the solid state drive (SSD).
  6. HP Spectre x2 12-a002dx SSD Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the PM2.0x2.5 screw on the SSD using a JIS00 screwdriver.
    • Store the screw in a safe place. You will need it to secure the replacement SSD in place.
  7. HP Spectre x2 12-a002dx SSD Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Next, carefully peel the sticker on top of the SSD off.
  8. HP Spectre x2 12-a002dx SSD Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Spectre x2 12-a002dx SSD Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully, pull the SSD out of the slot at an angle.
Talha Bin Amir
crwdns2935283:010/23/17crwdne2935283:0
684 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S10-G6, Thompson Fall 2017 crwdns2935289:0USF Tampa, Team S10-G6, Thompson Fall 2017crwdne2935289:0
USFT-THOMPSON-F17S10G6
Hola, esta unidad se puede cambiar, la memoria RAM se puede aumentar. Ha hecho un video al respecto.
Angel Cervantes Ramirez - crwdns2934203:0crwdne2934203:0
Me temo que no, la memoria esta soldada en la placa base.
fnpulido - crwdns2934203:0crwdne2934203:0
it would be nice if you listed the compatible ssds… key, interface, etc.
Alec Kristi - crwdns2934203:0crwdne2934203:0
it is a m.2 interface and it compatible with all 2280 size drives
Dean Cadry -
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 5,520
