HP ProBook 640 G2 Fan Replacement
    1. HP ProBook 640 G2 Fan Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Flip the laptop so the bottom is facing up.
      • Use a JIS J1 screwdriver to remove eight 6 mm screws from the bottom of the laptop case.
      • Use a Torx T9 screwdriver to remove the single 6 mm screw.
    2. HP ProBook 640 G2 Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a plastic opening tool to carefully pry the bottom case.
      • Insert the end of the opening tool into the seam between the bottom and top case and slide it around the perimeter to release the clips.
      • Remove the bottom cover.
    3. HP ProBook 640 G2 Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP ProBook 640 G2 Fan Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP ProBook 640 G2 Fan Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a JIS J1 screwdriver to remove the seven 6 mm screws securing the battery.
      • Lift the battery from the bottom edge and slide it out of the socket on the motherboard.
    1. HP ProBook 640 G2 Fan Replacement, Hard Drive: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Loosen the four JIS J1 captive screws on the hard drive tray.
      • Use the black tab on the hard drive tray and pull it toward the bottom of the laptop to remove the drive.
    2. HP ProBook 640 G2 Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP ProBook 640 G2 Fan Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP ProBook 640 G2 Fan Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use the JIS J1 screwdriver to remove the four 3.0 mm screws on the sides of the hard drive tray—two from each side.
      • Remove the old hard drive from the tray.
    1. HP ProBook 640 G2 Fan Replacement, RAM: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pull the disc drive out and set it aside.
    2. HP ProBook 640 G2 Fan Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP ProBook 640 G2 Fan Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Slide a thin spudger or angled tweezers under the metal neck of the connector (as close to the head as possible) and lift straight up from the Wireless WLAN card.
      • Pull straight up on the black tab to disconnect the display cable.
    3. HP ProBook 640 G2 Fan Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP ProBook 640 G2 Fan Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP ProBook 640 G2 Fan Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a JIS J1 screwdriver to remove the two 5 mm silver screws securing the hinge covers.
      • Turn the laptop over and open the top cover.
      • Use an opening tool to gently pry the plastic hinge covers off both hinges.
      • Lift the keyboard and pull it gently toward you to remove it from the laptop.
    4. HP ProBook 640 G2 Fan Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP ProBook 640 G2 Fan Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP ProBook 640 G2 Fan Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Turn the keyboard assembly over so the motherboard is facing up.
      • Gently pull the metal retaining clips away from the RAM module.
      • The RAM module will pop up at an angle.
      • Pull the RAM card out of its slot and replace with a new one.
      • When replacing the RAM, slide it in at the same angle it was removed, making sure the metal teeth are aligned with the slot. Push down until it snaps into place between the metal arms.
    1. HP ProBook 640 G2 Fan Replacement, Fan: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP ProBook 640 G2 Fan Replacement, Fan: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP ProBook 640 G2 Fan Replacement, Fan: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use the point of a spudger to push on alternating sides of the fan connector to "walk" it out of its socket.
      • It may take a lot of alternating before the connector comes out. Be patient, and don't pull on the cables.
      • If that doesn't work, use a pair of tweezers to firmly grip the sides of the connector and pull straight away from the socket. Hold the tweezers closer to the connector to get a better grip.
      • Use a JIS J1 screwdriver to loosen the six captive screws securing the fan and heat sink assembly.
    2. HP ProBook 640 G2 Fan Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Carefully lift out the fan and heatsink assembly.
      • Use compressed air to clean dust, or replace with a compatible fan if faulty.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Daniel Garcia
crwdns2935283:009/12/25crwdne2935283:0
196 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 1-1, Kilpatrick Fall 2025 crwdns2935289:0University of North Texas, Team 1-1, Kilpatrick Fall 2025crwdne2935289:0
UNT-KILPATRICK-F25S1G1
crwdns2935297:048crwdne2935297:0
crwdns2936753:030crwdne2936753:0 96
crwdns2942667:0crwdne2942667:0 435
