HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement
  1. HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Power down the device.
    • Flip the device face side down so the back of the device is facing up.
  2. HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a Phillips #00 screwdriver, remove the two 4.5 mm screws securing the battery cover located at the bottom center of the device.
    • Remove the cover.
  3. HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the battery.
  4. HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement, Button Panel: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement, Button Panel: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #00 screwdriver, remove the four 4.5 mm screws securing the back panel to the device.
  5. HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a spudger, gently pry apart the front and back panels.
  6. HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a Phillips #00 screwdriver, remove the eleven 3 mm screws securing the battery board/button panel located at the bottom half of the device.
    • Using a plastic opening tool, gently pry the retaining clip securing the ribbon cable to the top-left side of the board.
    • Using plastic tweezers, gently unplug the ribbon cable from the board.
  7. HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a plastic opening tool, gently pry upward on the battery board/button panel from the bottom to remove.
  8. HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement, Motherboard/Display: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement, Motherboard/Display: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the lower component from the motherboard
  9. HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a Phillips #00 screwdriver, remove the four screws securing the motherboard/display to the front panel.
    • Using a plastic opening tool, pry up the locking tab of the ZIF connector on the right side of the device and pull out the ribbon cable.
    • Using a plastic opening tool, gently pry apart the motherboard and the front panel.
  10. HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the motherboard from the display.
Eric A Bidema
crwdns2935283:009/16/20crwdne2935283:0
421 crwdns2915208:0crwdne2915208:0
The Citadel Military College of South Carolina, Team S2-G15, Eggleston Fall 2020 crwdns2935289:0The Citadel Military College of South Carolina, Team S2-G15, Eggleston Fall 2020crwdne2935289:0
CMCSC-EGGLESTON-F20S2G15
Hi Eric,
Do you know where we could buy / get a screen replacement? I looked everywhere, but I cannot find it.
Led Hilderink - crwdns2934203:0crwdne2934203:0
Hi, did you find it?
Alcides Cruz -
crwdns2936753:030crwdne2936753:0 80
crwdns2942667:0crwdne2942667:0 3,365
