Considering the steps in this guide were completed by 2 people, it is recommended to attempt this guide with 2 or more people.
Required Tools
- T-9 Screwdriver
- Needle-Nose Pliers
Pull down both front panels to open the printer. Lift the scanner flap upward by pulling down on it; there are two mouth pieces that need to be pulled down.
Adjust the flap covering the scanner upward, as shown.
Pull the scanner flap gently away from the printer to release its two clips.
Locate the three screws on top of the printer.
The orange circle shows a fourth screw located behind the power panel. Ignore this one for now, as directions to remove this screw are in Step 5.
Using a T-9 screwdriver, remove the three screws from the printer's top.
Reach inside the printer's front opening.
Press the small clip behind the power button.
Pull the panel out from right to left.
Remove the fourth screw, which was covered by the power button panel.
Have one person lift the hood 2-3 inches.
Have the other person disconnect the three cables from the motherboard (the green PCB) to the hood by gently pulling upward on them.
Remove the hood completely.
Remove the single T-9 screw from the hood's underside, as shown.
With the screw removed, separate the two pieces of the hood by lifting it vertically.
Carefully pull down the white ribbon cable through the top piece of the hood.
To release the LCD, locate the two mounting slots, and push the sloped slides inward to release the LCD from its slots.
Slide the LCD module downward to remove it from its holders.
The large ribbon wire from the LCD can be detached if needed.
