HP Pavilion x360 Convertible 14-dw1025nr Motherboard Replacement
  1. HP Pavilion x360 Convertible 14-dw1025nr Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 Convertible 14-dw1025nr Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 Convertible 14-dw1025nr Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn off the device and set it upside down. Orient the hinges away from you.
    • Wedge the opening pick under the grip. Lift the end of the grip.
    • Pull the grip off all the way. Repeat for the second grip.
  2. HP Pavilion x360 Convertible 14-dw1025nr Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 Convertible 14-dw1025nr Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 Convertible 14-dw1025nr Motherboard Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the 3 mm screw from the center bottom.
    • Use a Phillips #1 screwdriver to remove the 6 mm screw from all four corners of the bottom cover.
  3. HP Pavilion x360 Convertible 14-dw1025nr Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 Convertible 14-dw1025nr Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 Convertible 14-dw1025nr Motherboard Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the opening pick to separate the back panel from the device.
    • Begin near the hinge and carefully follow the perimeter until you have taken the pick around all four sides.
    • The back panel will come loose once the pick has been around the whole edge of the device.
    • Lift the panel off.
  4. HP Pavilion x360 Convertible 14-dw1025nr Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion x360 Convertible 14-dw1025nr Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove all four of the 4 mm screws that secure each corner of the battery.
  5. HP Pavilion x360 Convertible 14-dw1025nr Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 Convertible 14-dw1025nr Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 Convertible 14-dw1025nr Motherboard Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the opening tool near the connector to gently apply pressure and lift the battery away from the device.
    • Once loose, lift the battery from the connector side to separate it from the device.
    • The stabilizer for the battery (small black part held in by the top left screw) may come loose. Leave the part in its original position.
  6. HP Pavilion x360 Convertible 14-dw1025nr Motherboard Replacement, Motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion x360 Convertible 14-dw1025nr Motherboard Replacement, Motherboard: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect connectors 1 and 2 of the wireless card using the spudger.
  7. HP Pavilion x360 Convertible 14-dw1025nr Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion x360 Convertible 14-dw1025nr Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use PH1 to remove the 2.5mm holding screw.
    • Lift the card up and out.
  8. HP Pavilion x360 Convertible 14-dw1025nr Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion x360 Convertible 14-dw1025nr Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the spudger to disconnect the power connector.
  9. HP Pavilion x360 Convertible 14-dw1025nr Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the pointy end of the spudger to disconnect the webcam.
    • There are indents on either side of the connector that the pointy end of the spudger fits into.
  10. HP Pavilion x360 Convertible 14-dw1025nr Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion x360 Convertible 14-dw1025nr Motherboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    $3.99
    • Remove the sticker covering the touch sensor connector using the angled tweezers.
    • Firmly pinch the plastic loop and pull straight up to disconnect the touch sensor.
    • This connector is very tight and will likely make a pop sound when it disconnects.
  11. HP Pavilion x360 Convertible 14-dw1025nr Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the spudger to disconnect the cable to the left of the touch sensor connector.
  12. HP Pavilion x360 Convertible 14-dw1025nr Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 Convertible 14-dw1025nr Motherboard Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 Convertible 14-dw1025nr Motherboard Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Be sure not to scratch or puncture the ribbon cable.
    • Use the spudger to lift the black flap of the keyboard connector.
    • Use the angled tweezers to carefully grip and pull out the ribbon cable.
  13. HP Pavilion x360 Convertible 14-dw1025nr Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 Convertible 14-dw1025nr Motherboard Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 Convertible 14-dw1025nr Motherboard Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the angled tweezers to remove the clear sticker covering the trackpad connector.
    • Use the spudger to lift the white flap of the connector.
    • Use the angled tweezers to pull out the ribbon cable.
  14. HP Pavilion x360 Convertible 14-dw1025nr Motherboard Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the spudger to disconnect the fan cable.
  15. HP Pavilion x360 Convertible 14-dw1025nr Motherboard Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 Convertible 14-dw1025nr Motherboard Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 Convertible 14-dw1025nr Motherboard Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use PH1 to remove the 3 4mm screws holding the fan.
    • Lift the fan up and away from the heat pipe.
  16. HP Pavilion x360 Convertible 14-dw1025nr Motherboard Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion x360 Convertible 14-dw1025nr Motherboard Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use PH1 to remove the 7 2.5mm screws holding down the motherboard
    • Both battery stabilizers (small, black plastic parts) will be loose.
  17. HP Pavilion x360 Convertible 14-dw1025nr Motherboard Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slightly lift the heat pipe with one hand.
    • Using your other hand, lift the small part of the motherboard up and away from the laptop frame.
    • The silver section under the heat pipe is a ribbon cable that connects the small piece to the large section of the motherboard.
  18. HP Pavilion x360 Convertible 14-dw1025nr Motherboard Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion x360 Convertible 14-dw1025nr Motherboard Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the right side of the large portion of the motherboard up and away from the frame of the laptop.
Amber Norton
crwdns2935283:009/14/22crwdne2935283:0
661 crwdns2915208:0crwdne2915208:0
Western Carolina University, Team 1-3, Virtue Fall 2022 crwdns2935289:0Western Carolina University, Team 1-3, Virtue Fall 2022crwdne2935289:0
WCU-VIRTUE-F22S1G3
crwdns2942667:0crwdne2942667:0 745
