HP Pavilion x360 14m-cd0003dx Battery Replacement
  1. HP Pavilion x360 14m-cd0003dx Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn off the computer.
    • Disconnect the power cord and any external devices connected to the computer.
    • Make sure the device is completely turned off or else you may risk injury through electric shock.
  2. HP Pavilion x360 14m-cd0003dx Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion x360 14m-cd0003dx Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the device so that the back plate of the laptop is up.
    • Use a Phillips #0 screwdriver to remove the four 6 mm Phillips screws from the bottom cover.
    • You might have to use a spudger to remove any rubber bezels that cover the screws.
    • Pry off the back cover with the spudger tool.
    There must be some newer, or older versions of this model. My notebook is definitely 14m-cd0003dx but I had a different screw pattern on the bottom plate: only the two back rubber bezels had screws underneath and there were 3 screws along the front edge of the back plate…
    Monte87 - crwdns2934203:0crwdne2934203:0
  3. HP Pavilion x360 14m-cd0003dx Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 14m-cd0003dx Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 14m-cd0003dx Battery Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the six 5 mm battery screws, and the battery can then be taken out.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Mason T Arruda
crwdns2935283:003/22/22crwdne2935283:0
171 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 7-4, Sinclaire Spring 2022 crwdns2935289:0UMass Dartmouth, Team 7-4, Sinclaire Spring 2022crwdne2935289:0
UMASSD-SINCLAIRE-S22S7G4
crwdns2931471:06crwdne2931471:0
Hallo
vielen Dank für diese coole Anleitung
als Ergänzung
beim Model 14-cd0101ng gibt es lediglich die beiden unteren Schrauben (siehe schritt, zwei 6mm schrauben) nicht.
Ansonsten konnte ich keine unterschiede feststellen!
Eng:
For Model 14-cd0101ng it is the same way, without the two 6mm Phillips screws underneath!
Erwin “ReudenBub” Po - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 41
crwdns2942667:0crwdne2942667:0 2,333
