If you are having complications with laptop having to boot and then shutting off, or blue screens of death, you may want to replace the motherboard.
Flip your device over so the bottom panel is facing up.
Use the plastic opening tool to remove the back panel.
Use the PH 1 screwdriver to remove the four 3.5 mm screws securing the hard drive.
Lift the corner bracket to remove the hard drive.
Unplug the hard drive wire to detach the hard drive.
Don't forget to unplug 2 connectors next to the drive's connector. They're not mentioned anywhere in the guide but you won't remove the motherboard with them.
Remove a 3.5 mm screw that is securing DVD player with screwdriver PH1.
Slide DVD player to the left and pull to remove completely.
Unscrew four 3.5 mm screws from the inside of the battery compartment with PH 1 screwdriver.
Unscrew nine 5 mm screws with PH 1 screwdriver.
Unscrew four 4 mm screws with PH 1 screwdriver.
Flip side up and open laptop.
Pry open the keyboard using a plastic opening tool starting from the top.
Lift up plastic cover over keyboard connector cable.
Pull ribbon cable up away from keyboard to completely remove.
Remove seven 4mm pannel screws with PH 1 screwdriver.
Place the computer on its side
Separate top panel from bottom frame.
Pull ribbon to detach from bottom panel.
Remove two 5mm screws securing fan, using PH1 screwdriver.
You forgot about the screw that secures the motherboard on the bottom left. It's in the photo.
Flip laptop over.
Remove two 4mm screws securing antenna using PH 1 screwdriver.
Pull antenna to the right to remove.
Flip laptop side up.
Pull off yellow insulating tape.
Grab tab on left top corner and remove black wire.
Remove white input attachment.
Hold the motherboard and pull to the right.
crwdns2935229:010crwdne2935229:0
crwdns2947412:05crwdne2947412:0
Great tutorial. Thanks!!!!
Nothing, thank you very much, it is a pleasure to help more people
very Excellent tutorial …… Thank you
Excellent tutorial …. thank you
Tomas -
