HP Pavilion HDX9000 Motherboard Replacement
  1. HP Pavilion HDX9000 Motherboard Replacement, Remove battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide battery latch to the right as pictured to release the battery.
  2. HP Pavilion HDX9000 Motherboard Replacement, Remove disc drive: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single screw securing the disc drive.
    • Pull on the disc drive faceplate to remove the disc drive.
  3. HP Pavilion HDX9000 Motherboard Replacement, Remove hard drive(s): crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion HDX9000 Motherboard Replacement, Remove hard drive(s): crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the six captive screws securing the hard drive door to the base.
    • Unscrew the captive screw securing each hard drive.
    • Slide each caddy by its tab away from its SATA connector, and pull the caddy out of the computer.
  4. HP Pavilion HDX9000 Motherboard Replacement, Remove keyboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion HDX9000 Motherboard Replacement, Remove keyboard: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two M2.5x8 screws securing the keyboard.
    • Remove the four M2.5x5 screws securing the keyboard.
    • Remove the two captive screws securing the TV card door to the base.
    • Remove the cover to reveal one more long keyboard screw.
    • Flip the computer over and open it. Then, lightly pry the keyboard off from the front (below the keyboard). Beware of adhesive.
    • Remove the keyboard connector.
  5. HP Pavilion HDX9000 Motherboard Replacement, Remove hinge cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four screw covers, and then each of the M3x8 screws under them. Beware, these are different from the others.
    • The hinge cover then slides back and off.
  6. HP Pavilion HDX9000 Motherboard Replacement, Remove rear cover: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion HDX9000 Motherboard Replacement, Remove rear cover: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion HDX9000 Motherboard Replacement, Remove rear cover: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the seven M2.5x8 screws securing the palmrest panel. These screws all have arrows pointing to them.
    • Remove the four oddball M2.5x4 broad-head screws under where the battery was.
    • There is also another screw, under where the disc drive faceplate was, which has a screw cover on top of it. This screw has an arrow pointing to it, too. This screw is of an M2.5x4 size.
    • Remove the four M3x12 screws. These, too, are different from the others, so keep them separate.
    • Flip the laptop over, open it, and pull up on the palmrest panel (or use a plastic spudger).
  7. HP Pavilion HDX9000 Motherboard Replacement, Remove palmrest: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion HDX9000 Motherboard Replacement, Remove palmrest: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the laptop upside-down again, and remove the ten M2.5x8 screws securing the palmrest to the base.
    • Remove the two screw covers on the screws under where the disc drive faceplate was, and then remove each M2.5x4 screw.
    • Remove the four M2.5x5 screws securing the palmrest to the base.
    • Remove the two M2.5x11 screws securing the palmrest to the base.
    • Flip the laptop over, and...
    • ...wait, don't pull the palmrest off yet!
    • Disconnect each cable.
    • Remove the two M2.5x5 screws, and now you may go around with a plastic spudger and separate the palmrest from the base.
  8. HP Pavilion HDX9000 Motherboard Replacement, Remove subwoofer: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion HDX9000 Motherboard Replacement, Remove subwoofer: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the subwoofer and CPU fan cables.
    • Remove the three M2.5x8 screws securing the subwoofer to the base.
    • Don't over-tighten these screws when reinstalling the subwoofer!
  9. HP Pavilion HDX9000 Motherboard Replacement, Remove Wi-Fi card & antennas: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion HDX9000 Motherboard Replacement, Remove Wi-Fi card & antennas: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion HDX9000 Motherboard Replacement, Remove Wi-Fi card & antennas: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the laptop over and unscrew the captive screw securing the Wi-Fi door to the base.
    • Remove each antenna from the Wi-Fi card by pulling up on its connector.
    • Remove the two M2.5x5 screws securing the Wi-Fi card, and remove the card.
    • Remove the two M2.5x5 screws securing the TV tuner card, and remove the card.
  10. HP Pavilion HDX9000 Motherboard Replacement, Remove CPU fan: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two M2.5x8 screws securing the CPU fan to the base, and remove the fan.
  11. HP Pavilion HDX9000 Motherboard Replacement, Remove motherboard cables: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion HDX9000 Motherboard Replacement, Remove motherboard cables: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion HDX9000 Motherboard Replacement, Remove motherboard cables: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the power connector up and out.
    • Pull all four antennas out from under the motherboard.
    • Remove all cable connectors from the motherboard.
  12. HP Pavilion HDX9000 Motherboard Replacement, Remove motherboard screws: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion HDX9000 Motherboard Replacement, Remove motherboard screws: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion HDX9000 Motherboard Replacement, Remove motherboard screws: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two M1.5x9 screws on each side of the Expansion Port connector.
    • Remove the four M2.5x4 screws securing the motherboard to the base.
  13. HP Pavilion HDX9000 Motherboard Replacement, Remove motherboard: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the single captive screw securing the video card fan to the base.
    • Pull up on the motherboard's right side slowly, and then it will come out.
    • Congratulations, you have survived! Now you just need to transfer the coolers, CPU, and video card to the new motherboard.
Joseph Sctbunio
crwdns2935283:009/23/17crwdne2935283:0
7,578 crwdns2915208:0crwdne2915208:0
crwdns2935297:042crwdne2935297:0
crwdns2942667:0crwdne2942667:0 3,573
