HP Pavilion 15-p Optical drive Replacement
  1. crwdns2935267:0crwdne2935267:0
    Essential Electronics Toolkit
    $29.95
    • Toolkit change note: Due to the EET missing several bits present in the Pro Tech Go and only being $20 cheaper, the EET has been removed. The EET has everything needed to complete this guide if you already own one, but if you are shopping for a new toolkit to complete this for the first time, the Pro Tech Go or refurbished Pro Tech is the current recommended kit.
  2. HP Pavilion 15-p Optical drive Replacement, Prepare the laptop: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-p Optical drive Replacement, Prepare the laptop: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-p Optical drive Replacement, Prepare the laptop: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Shut the laptop down until it is hibernated or shut off. Do not remove power until both lights turn off.
  3. HP Pavilion 15-p Optical drive Replacement, Unlock the  battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-p Optical drive Replacement, Unlock the  battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-p Optical drive Replacement, Unlock the  battery: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once the computer is off, remove the battery. Switch the locking tab to the unlocked position.
  4. HP Pavilion 15-p Optical drive Replacement, Remove the battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion 15-p Optical drive Replacement, Remove the battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery. Pull the battery forward and remove it from the laptop.
  5. HP Pavilion 15-p Optical drive Replacement, Remove the screw: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-p Optical drive Replacement, Remove the screw: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-p Optical drive Replacement, Remove the screw: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • EET owners: Your kit has this bit. No purchase needed.
    • Remove the screw that holds the optical drive in. To do this, use a Phillips #0 screwdriver. Slide the optical drive out once this screw is removed.
  6. HP Pavilion 15-p Optical drive Replacement, Remove the optical drive tab: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion 15-p Optical drive Replacement, Remove the optical drive tab: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screws holding the optical drive bracket onto the drive. To do this, use a Phillips #0 screwdriver.
  7. HP Pavilion 15-p Optical drive Replacement, Faceplate removal: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-p Optical drive Replacement, Faceplate removal: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-p Optical drive Replacement, Faceplate removal: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Be careful not to break any clips. The faceplate will still be usable, but will be loose fitting.
    • To remove the faceplate, open the optical drive with a paper clip. Once the tray is released, use a flat tool to release the visible clip on the faceplate. Once done, the faceplate should come off.
Nick
crwdns2935283:011/10/09crwdne2935283:0
97,226 crwdns2915208:0crwdne2915208:0
crwdns2935297:061crwdne2935297:0
Master Techs crwdns2935289:0Master Techscrwdne2935289:0
Community
crwdns2931471:0328crwdne2931471:0
crwdns2935297:01,438crwdne2935297:0
crwdns2942667:0crwdne2942667:0 7,981
