This guide will aid in replacement of the hard drive in an HP Pavilion 15-n232nr. The process is fairly time consuming due to keyboard removal. Screwdriver, plastic opener, metal spudger, and tweezers are the necessary tools.
Slide the battery locks towards the center of the laptop. The battery will detach automatically.
Remove the battery by sliding it away from the laptop housing.
Unscrew the 6 mm Phillips #1 screw securing the keyboard.
Flip the laptop to the front side and open it up.
Use the metal spudger to release the keyboard from the front panel.
Flip the keyboard out and locate the connector.
Use the spudger to unhinge the the fastener and remove the connector.
Remove the 6 mm Phillips #1 screw securing the optical drive.
Use the iFixit opening tool to slide the optical drive away from the laptop housing.
Remove the ten 6 mm Phillips #1 screws.
Remove the three 1 mm Phillips #000 screws.
There are also 3 screws that need to be removed under the Wireless/RAM back panel.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Remove the five 2.5mm Phillips #1 screws.
Use the spudger to unhinge the cable connectors. Use tweezers to complete removal.
Carefully use the iFixit opening tool to release the front panel.
Use the spudger to unhinge the daughterboard connector.
Remove daughterboard connector.
Remove the 2.5 mm Phillips #1 screw and remove the daughterboard
Use the iFixit opening tool to remove the hard drive connector.
Remove the hard drive by lifting the right side and pulling it out.
How to test it's processor
Great guide, thank you!!
