HP Pavilion 15-ab165us Battery and Back Cover Replacement
  1. HP Pavilion 15-ab165us Battery and Back Cover Replacement, Battery and Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion 15-ab165us Battery and Back Cover Replacement, Battery and Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the computer over so that the bottom cover is facing you.
    • Slide the two locks to the "unlock" position and remove the battery.
  2. HP Pavilion 15-ab165us Battery and Back Cover Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-ab165us Battery and Back Cover Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-ab165us Battery and Back Cover Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 8mm screws underneath with a Phillips #1 screwdriver.
    • Use a plastic opening tool to remove the plastic feet.
    Plastic feet are actually the feet bezels. They snap out
    Steven Wander - crwdns2934203:0crwdne2934203:0
  3. HP Pavilion 15-ab165us Battery and Back Cover Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-ab165us Battery and Back Cover Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-ab165us Battery and Back Cover Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two plastic tabs with a metal spudger.
    What are the plastic tabs part number
    Regina Bowman - crwdns2934203:0crwdne2934203:0
  4. HP Pavilion 15-ab165us Battery and Back Cover Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the sixteen 8mm screws that hold the bottom cover with a Phillips #1 screwdriver.
    There are 2 under the rear foot plastic covers that are not mentioned to remove, they snap out
  5. HP Pavilion 15-ab165us Battery and Back Cover Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the Optical Drive out.
    How do I pull the optical drive out if the computer is off?
    killertofu - crwdns2934203:0crwdne2934203:0
  6. HP Pavilion 15-ab165us Battery and Back Cover Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 3mm screws that were hidden under the Optical Drive with a Phillips #0 screwdriver.
    Any other way to remove these screws? Phillips #00 wasn't working for
    mjsbak - crwdns2934203:0crwdne2934203:0
    These screws are insanely tight for some reason. Only a good sharp #0 will work, otherwise you could notch the side and tap it loose CCW with a punch.
    Unable to open these screws as they seem to be worn out… any other method would be helpful
    Abhi - crwdns2934203:0crwdne2934203:0
    These screws do not budge! My 0 screwdriver not working. How do we remove them?
    Jules Ju - crwdns2934203:0crwdne2934203:0
  7. HP Pavilion 15-ab165us Battery and Back Cover Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion 15-ab165us Battery and Back Cover Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the computer back over.
    • Use a plastic opening tool to release the clips holding the keyboard section in place.
    What can I use if I don’t have a plastic opening tool?
    Nancy Carr Saunders - crwdns2934203:0crwdne2934203:0
  8. HP Pavilion 15-ab165us Battery and Back Cover Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Close the lid and pull the screen and keyboard section up and away from the disconnected bottom cover.
    • The hard drive is NOT screwed into place on the underside of the keyboard section.
    Note that before you remove the bottom cover, there are three plastic snaps on the back of the PC where the battery would go. These have to be detached before the entire bottom cover can be freed from the top panel.
    Kieran - crwdns2934203:0crwdne2934203:0
    I thought there was something they missed. Mine finally seperated with a loud snap.Thought I broke something but it looks ok. These parts are pretty tough.
    Steven Wander -
    The explanations are very good detailed and pictures help to understand it, however, if all the process is described in a video would be a lot better for sure.
    Billmart - crwdns2934203:0crwdne2934203:0
    This also works on the HP Pavilion ab130na.
    Filip Olczyk - crwdns2934203:0crwdne2934203:0
crwdns2935229:010crwdne2935229:0
Dillon Hubble
crwdns2935283:010/20/17crwdne2935283:0
653 crwdns2915208:0crwdne2915208:0
UW Tacoma, Team S1-G2, Rose Fall 2017 crwdns2935289:0UW Tacoma, Team S1-G2, Rose Fall 2017crwdne2935289:0
UWT-ROSE-F17S1G2
Where can i buy the case? I couldn’t anywhere online??
Model - HP Pavilion 15 8th gen B&O
Jackson Beno - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 52
crwdns2942667:0crwdne2942667:0 66,549
