HP Pavilion 14-b120dx Audio Port/USB Drive Replacement
  1. HP Pavilion 14-b120dx Audio Port/USB Drive Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Power down the laptop and detach the charging cord (failure to do so can result in electrical shock).
  2. HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the laptop upside down so that the bottom is facing you.
    • Push the slide on the right toward the center of the laptop, releasing the battery latch.
    • Lift the battery up and away from the laptop.
  3. HP Pavilion 14-b120dx Audio Port/USB Drive Replacement, Keyboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 14-b120dx Audio Port/USB Drive Replacement, Keyboard: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 14-b120dx Audio Port/USB Drive Replacement, Keyboard: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the plastic opening tool between the keyboard and the palm rest.
    • Pry upwards until the keyboard section detaches from the laptop.
    • Repeat this around the edge of the entire keyboard.
    • Sections will make loud snapping noises as they detach from the palm rest - this is normal.
    there are 2 screws on the back that are marked with a mini keyboard. these have to be removed before lifting the keyboard
    John Bollman - crwdns2934203:0crwdne2934203:0
    Insert the opening tool at the back of the keyboard, not the front!
    Philip Le Riche - crwdns2934203:0crwdne2934203:0
  4. HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the keyboard slowly up until the connecting cable is exposed.
    • Carefully lift the flap on the ZIF connector using a fingernail or plastic opening tool. This will release the cable.
    • Detach the cable.
    Lift the back of the keyboard, not the front!
  5. HP Pavilion 14-b120dx Audio Port/USB Drive Replacement, Palm Rest: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion 14-b120dx Audio Port/USB Drive Replacement, Palm Rest: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the 10 6.0 mm screws under the keyboard housing with a Philips #0 head screwdriver.
    2 of these marked locations are the holes for the keyboard screws
  6. HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the plastic opening tool into the seam between the palm rest and the laptop.
    • Pry upwards until the palm rest separates from the laptop.
    • Repeat this process around the entire computer.
    • These steps will be similar to the ones you took to remove the keyboard. Again, you will hear snapping noises.
  7. HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift upwards to remove the palm rest.
  8. HP Pavilion 14-b120dx Audio Port/USB Drive Replacement, Audio Port and USB drive: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion 14-b120dx Audio Port/USB Drive Replacement, Audio Port and USB drive: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully disconnect the cable connecting the ports to the motherboard from the right side.
  9. HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 6.0 mm screws from the ports.
  10. HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the ports to the left and lift upward to remove them safely.
Erin Lavalla
crwdns2935283:010/18/16crwdne2935283:0
458 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 4-4, Catania Fall 2016 crwdns2935289:0UMass Dartmouth, Team 4-4, Catania Fall 2016crwdne2935289:0
UMASSD-CATANIA-F16S4G4
where can I find the replacement part?
edwin abraham - crwdns2934203:0crwdne2934203:0
Hello, first I just wanted to say thank you so much for writing these guides! You’re a super hero…. now then, I find myself in quite a pickle. I have an HP 15-b123cl with a screen that’s broken. I need to resolder one of the connectors. I have a picture that will show you which connector I need to fix, but I can’t post a picture in this comment section… all I need is a picture of the display connector on the top left of the motherboard. I even checked ifixit for some way of messaging you directly, but no luck :(… all I can think to do is give you my personal email address and hope that you send me something! Anyways… THANKS ERIN
Ethan
ejstepanianATgmail.com
Ethan Stepanian - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 874
