HP LaserJet 1160 or 1320 Fuser Replacement
  1. HP LaserJet 1160 or 1320 Fuser Replacement, Left Side Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP LaserJet 1160 or 1320 Fuser Replacement, Left Side Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP LaserJet 1160 or 1320 Fuser Replacement, Left Side Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull on the two tabs on the back of the printer to release the left side cover.
    • Remove the cover by rotating it towards the front of the printer.
  2. HP LaserJet 1160 or 1320 Fuser Replacement, Right Side Cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP LaserJet 1160 or 1320 Fuser Replacement, Right Side Cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP LaserJet 1160 or 1320 Fuser Replacement, Right Side Cover: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the printer turned so that the right side is facing upwards, use a metal spudger to disengage 3 tabs holding the right side cover in place.
    • Lift the cover off of the printer.
  3. HP LaserJet 1160 or 1320 Fuser Replacement, Back Cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP LaserJet 1160 or 1320 Fuser Replacement, Back Cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP LaserJet 1160 or 1320 Fuser Replacement, Back Cover: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove 4 screws on the back of the printer.
    • Remove the back cover.
    для чистки соленоида зад снимать не обязательно.
    liv 63 - crwdns2934203:0crwdne2934203:0
  4. HP LaserJet 1160 or 1320 Fuser Replacement, Top Cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP LaserJet 1160 or 1320 Fuser Replacement, Top Cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP LaserJet 1160 or 1320 Fuser Replacement, Top Cover: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove 2 screws on the back of the printer, one on the left, and one on the front.
    • The second image shows the formatter removed, but it is not necessary to remove the formatter to replace the top cover.
  5. HP LaserJet 1160 or 1320 Fuser Replacement, Top Cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the control panel cable and remove the top cover.
  6. HP LaserJet 1160 or 1320 Fuser Replacement, Fan: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP LaserJet 1160 or 1320 Fuser Replacement, Fan: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the fan cable from the main board of the printer.
    • Remove the retaining clip holding the fan in.
    • Remove the 2 screws holding the fan in.
  7. HP LaserJet 1160 or 1320 Fuser Replacement, Fan Cable: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP LaserJet 1160 or 1320 Fuser Replacement, Fan Cable: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP LaserJet 1160 or 1320 Fuser Replacement, Fan Cable: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the fan cable from the cable guide.
  8. HP LaserJet 1160 or 1320 Fuser Replacement, Duplexer PCB: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP LaserJet 1160 or 1320 Fuser Replacement, Duplexer PCB: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect one cable from the main board of the printer.
    • Disconnect the duplexer solenoid cable from the duplexer PCB.
    • Remove one screw on the duplexer PCB and remove the PCB from the printer.
  9. HP LaserJet 1160 or 1320 Fuser Replacement, Duplexer Gears: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP LaserJet 1160 or 1320 Fuser Replacement, Duplexer Gears: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove 3 screws holding the duplexer gears to the printer and remove the gears.
    а вот здесь внимательнее: снимая эту часть, придерживайте колесики, иначе вылетят - хрен соберешь !
  10. HP LaserJet 1160 or 1320 Fuser Replacement, Duplexer Solenoid: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove one screw to remove the solenoid from the printer.
  11. HP LaserJet 1160 or 1320 Fuser Replacement, Left Side Cover: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP LaserJet 1160 or 1320 Fuser Replacement, Left Side Cover: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP LaserJet 1160 or 1320 Fuser Replacement, Left Side Cover: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  12. HP LaserJet 1160 or 1320 Fuser Replacement, Formatter: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP LaserJet 1160 or 1320 Fuser Replacement, Formatter: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP LaserJet 1160 or 1320 Fuser Replacement, Formatter: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove 2 screws on the I/O port cover.
    • Remove 6 screws on the formatter.
    • Disconnect 3 connectors from the formatter.
    • Disconnect 2 flat flexible cables from the formatter.
    • Remove the formatter from the printer.
    • Be careful not to fold, crease, or tear flat flexible cables.
    • The I/O port cover will need to be transferred to the new formatter before installing it.
  13. HP LaserJet 1160 or 1320 Fuser Replacement, Fuser Gear: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP LaserJet 1160 or 1320 Fuser Replacement, Fuser Gear: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the fuser gear by pushing in on the tab with a metal spudger.
  14. HP LaserJet 1160 or 1320 Fuser Replacement, Tray Connector: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP LaserJet 1160 or 1320 Fuser Replacement, Tray Connector: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP LaserJet 1160 or 1320 Fuser Replacement, Tray Connector: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the cable to the tray connector and route it through the hole in the chassis.
  15. HP LaserJet 1160 or 1320 Fuser Replacement, Fuser Cables: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP LaserJet 1160 or 1320 Fuser Replacement, Fuser Cables: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP LaserJet 1160 or 1320 Fuser Replacement, Fuser Cables: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect 2 cables from the main board and route them through the cable guide.
  16. HP LaserJet 1160 or 1320 Fuser Replacement, Fuser Cables: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP LaserJet 1160 or 1320 Fuser Replacement, Fuser Cables: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the cable guide from the chassis.
  17. HP LaserJet 1160 or 1320 Fuser Replacement, Fuser Cables: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP LaserJet 1160 or 1320 Fuser Replacement, Fuser Cables: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP LaserJet 1160 or 1320 Fuser Replacement, Fuser Cables: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the cable guide from the other side of the chassis.
    • Disconnect 2 cables from the main board.
  18. HP LaserJet 1160 or 1320 Fuser Replacement, Fuser Cables: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP LaserJet 1160 or 1320 Fuser Replacement, Fuser Cables: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use needle nose pliers to disconnect the high voltage wire from the fuser.
  19. HP LaserJet 1160 or 1320 Fuser Replacement, Fuser Cables: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP LaserJet 1160 or 1320 Fuser Replacement, Fuser Cables: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP LaserJet 1160 or 1320 Fuser Replacement, Fuser Cables: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the tray connector cable from the cable guide.
    • Disconnect the main motor cable.
  20. HP LaserJet 1160 or 1320 Fuser Replacement, Fuser: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP LaserJet 1160 or 1320 Fuser Replacement, Fuser: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP LaserJet 1160 or 1320 Fuser Replacement, Fuser: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove 3 screws from the right side of the printer.
    • Remove 3 screws from the left side of the printer.
    • The fuser assembly can now be removed from the printer.
jdp23
crwdns2935283:008/22/13crwdne2935283:0
1,312 crwdns2915208:0crwdne2915208:0
crwdns2935297:023crwdne2935297:0
Do you the ohmmeter reading for the fuser’s two electrical cables? I have ok for the one with two black cables, no reading for the black and white one.
jeangould - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 5,940
