Is the CPU fan in your HP Envy x360 m6-aq103dx not functioning correctly? Follow this easy replacement guide to open up your computer and replace the CPU fan.
Flip the laptop over to expose the underside.
Remove the two grip pads with blue plastic opening tool by inserting the tool between the laptop and the pads and slowly lifting up.
Remove the two 8 mm Phillips Head screws that were under the grip pads using a Phillip's Head 1 Screwdriver.
Remove the six 5 mm Torx screws using a T5 Torx Screwdriver.
Use the nylon spudger to pop off the bottom cover by inserting it into the heat vent and twisting to the left or right.
The case is secured by plastic hooks at 1” intervals. Use the nylon spudger and the opening tool to lever around the rim of the case. Start at the edge of the heat vent and work around the rim. Each plastic fastener will make a popping noise as they release.
Disconnect the port of the fan by flipping the black tab with the small blue plastic opening tool.
Remove the cable from the connector.
Peel back a little bit of the grey tape connected to the round cable with the big blue opening tool.
Using your fingers, peel the tape off of the body of the computer.
Remove the black cable from the fan by unclicking it from the plastic body of the fan with your fingers and move it out of the area.
Disconnect the port with the red yellow and blue wires by dislodging the wires with your fingers.
Remove the two 4.5mm Phillips #1 screws.
Loosen the four black screws by the curved heat sink with a Phillips head 1 screwdriver.
Lift the CPU fan out with your hand.
Would you recommend replacing just the fan or the fan and the other part as well (the L shaped thing attached to it)? I bought just the fan, but I'm afraid that's not enough to fix it.
Hi, I have replaced fan in my x360 but now the screen is blank, works on external. I’m wondering if I’ve damaged the screen ribbon cable or inserted it incorrectly! Can you tell me if the contacts should face up or down on the connector cable? Difficult to see on photos and foolishly didn’t note when I removed!
Step 5-7 can be bypassed I didn’t need to do it
My first home repair so far. Really easy to follow guide. Great job!
Purchased tools and did the steps, no issues. worth the tools to use later. Worked in iT anyways.
