HP EliteBook x360 830 G6 Cooling System Replacement
  1. HP EliteBook x360 830 G6 Cooling System Replacement, Unfasten the back cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Torx T5 screwdriver to loosen the five captive screws holding the back cover.
  2. HP EliteBook x360 830 G6 Cooling System Replacement, Release the clips: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP EliteBook x360 830 G6 Cooling System Replacement, Release the clips: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening pick between a corner of the back corner and the chassis, near a hinge.
    • Pry upward to release the retaining clips.
    • These clips will make an audible click when they release.
    • Repeat this process for the opposite corner.
  3. HP EliteBook x360 830 G6 Cooling System Replacement, Release the remaining clips: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP EliteBook x360 830 G6 Cooling System Replacement, Release the remaining clips: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert your opening pick between the back cover and chassis, along the edge of the cover between the hinges.
    • Pry up to release the additional retaining clips.
  4. HP EliteBook x360 830 G6 Cooling System Replacement, Remove the back cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP EliteBook x360 830 G6 Cooling System Replacement, Remove the back cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP EliteBook x360 830 G6 Cooling System Replacement, Remove the back cover: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab the cover by the corners next to the hinges.
    • Swing the cover open and away from you.
    • If the back cover feels stuck to the chassis, use an opening pick to release remaining clips around the perimeter of the back cover.
    • Lift and remove the back cover from the laptop body.
  5. HP EliteBook x360 830 G6 Cooling System Replacement, Disconnect the battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP EliteBook x360 830 G6 Cooling System Replacement, Disconnect the battery: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP EliteBook x360 830 G6 Cooling System Replacement, Disconnect the battery: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the point of a spudger to push the sides of the battery connector out of its socket.
    • Push on alternate sides to "walk" the connector out.
  6. HP EliteBook x360 830 G6 Cooling System Replacement, Cooling System: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP EliteBook x360 830 G6 Cooling System Replacement, Cooling System: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP EliteBook x360 830 G6 Cooling System Replacement, Cooling System: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the Phillips #0 screwdriver, remove the seven 3 mm screws from the cooling system.
  7. HP EliteBook x360 830 G6 Cooling System Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP EliteBook x360 830 G6 Cooling System Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP EliteBook x360 830 G6 Cooling System Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the three 3mm captive screws from the fan using the Philips 0 screwdriver.
    • Using needle nose tweezers, gently grab the base of the connection and pull to disconnect.
  8. HP EliteBook x360 830 G6 Cooling System Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the fan and cooling system from the motherboard.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our HP EliteBook community for help.
Bukari
crwdns2935283:009/01/21crwdne2935283:0
97 crwdns2915208:0crwdne2915208:0
Gateway, Team 1-2, Saknee Fall 2021 crwdns2935289:0Gateway, Team 1-2, Saknee Fall 2021crwdne2935289:0
GCC-SAKNEE-F21S1G2
crwdns2942667:0crwdne2942667:0 886
