This guide explains how to remove the hard drive from the laptop.
Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
Remove the remaining four 7.3 mm screws using the same screwdriver.
Separate the bottom cover from the laptop, starting from the upper corner and working your way around the edge.
Lift the black tape covering the solid state drive.
Remove the 2.4 mm screw using a Phillips #00 screwdriver.
This is an unecessary step you dont have to remove the SSD
Slide the solid state drive to the left and out of its port.
Which SSD is compatible with this computer?
Very nice its clear
J'ai un problème de son
