HP EliteBook x360 1030 G3 Battery Replacement
  1. HP EliteBook x360 1030 G3 Battery Replacement, Bottom Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Be sure to power off and unplug your device before you begin your repair.
    • Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
    • Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
    • Remove the remaining four 7.3 mm screws using the same screwdriver.
  2. HP EliteBook x360 1030 G3 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the bottom cover from the laptop, starting from the upper corner and working your way around the edge.
    • The plastic fastening may make cracking sounds when separating, but this is normal.
  3. HP EliteBook x360 1030 G3 Battery Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five 3.7 mm screws that are holding the battery in place using a Phillips #00 screwdriver.
    • Be sure to keep the screws organized because they will be reused for the next battery installation.
  4. HP EliteBook x360 1030 G3 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP EliteBook x360 1030 G3 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully pull the white plastic battery connector towards you until it is removed from the port.
    • Be sure not to pull using the wires; doing so may cause damage.
    Connector to the left may be stuck to the battery a little. Don’t worry just be careful.
    Leighton Doswell - crwdns2934203:0crwdne2934203:0
  5. HP EliteBook x360 1030 G3 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the battery out of its place.
    This is an unescasary step you dont have to remove the fan
crwdns2935229:010crwdne2935229:0
Pablo Arriola
crwdns2935283:004/22/19crwdne2935283:0
528 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S2-G9, Maness Spring 2019 crwdns2935289:0Cal Poly, Team S2-G9, Maness Spring 2019crwdne2935289:0
CPSU-MANESS-S19S2G9
crwdns2947412:05crwdne2947412:0
Looks easy and do you know if the pc can work without battery, only with charger?
Sam Uel - crwdns2934203:0crwdne2934203:0
Very simple and precise with good warnings too
Roland Appiah - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 32
crwdns2936753:030crwdne2936753:0 225
crwdns2942667:0crwdne2942667:0 13,834
