HP EliteBook 8530w RAM Replacement
  1. HP EliteBook 8530w RAM Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP EliteBook 8530w RAM Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the laptop off then place it down so that the back is facing up.
    • Slide the battery release switch to the left and hold it there.
  2. HP EliteBook 8530w RAM Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP EliteBook 8530w RAM Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the battery away upward and away from the laptop while continuing to hold the release switch.
    • Once the battery is removed from the laptop, you may release the switch.
    • To properly dispose of your battery, look for the closest location that accepts electronic waste in your area and drop it off there.
    The second bullet should be orange, not yellow
    John Lamothe - crwdns2934203:0crwdne2934203:0
    Also, how should they dispose of the batter?
  3. HP EliteBook 8530w RAM Replacement, RAM: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP EliteBook 8530w RAM Replacement, RAM: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP EliteBook 8530w RAM Replacement, RAM: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the two screws with a RAM/WiFi icon using a Phillips #00 screwdriver.
    • These screws are retained (not designed to be removed). Just loosen them.
    • After the screws are loosened, pull the cover off by lifting up from the side with the screws.
  4. HP EliteBook 8530w RAM Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP EliteBook 8530w RAM Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP EliteBook 8530w RAM Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once the cover is removed, you will see two rectangular RAM sticks as shown in the picture.
    • Pull each of the tabs holding the RAM in place apart from each other.
    • Little force is required to pull the tabs. Be careful when bending them back.
    • Once the tabs are pulled away, the RAM should pop up to rest at a 45º angle to the motherboard.
    Need a comma in that first bullet
  5. HP EliteBook 8530w RAM Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP EliteBook 8530w RAM Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the RAM out of the laptop in the direction the RAM is pointing at to remove it.
    • When inserting RAM into the laptop, make sure that when you fold the RAM down the tabs are holding it in place. You may hear a "click" from the tabs when you fold the RAM down. That means that the tabs should be holding the RAM.
Raymond Kwasneski
crwdns2935283:001/30/20crwdne2935283:0
511 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S14-G6, Lamothe Spring 2020 crwdns2935289:0Embry-Riddle Aeronautical University, Team S14-G6, Lamothe Spring 2020crwdne2935289:0
ERAU-LAMOTHE-S20S14G6
I just removed my 2G ram from the back as soy said but the laptop still can run.
At the slot of the ram I removed it has a number 3 and I am wondering if it is a "hidden" one?
Aggelos Printezis - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 750
