HP EliteBook 850 G5 Battery Replacement
    • Turn off the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
    • Disconnect the power from the computer by unplugging the power cord from the computer.
    • Disconnect all external devices from the computer.
    • Turn the computer upside down on a flat surface.
  1. HP EliteBook 850 G5 Battery Replacement, Remove the bottom cover screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Loosen the eight captive screws that secure the bottom cover.
    • Loosen the two inset captive screws that secure the bottom cover.
  2. HP EliteBook 850 G5 Battery Replacement, Remove the bottom cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Starting under the middle of the display, pry and lift the bottom cover off the computer. Consider using a spudger.
  3. HP EliteBook 850 G5 Battery Replacement, Disconnect the battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the battery cable from the system board.
    • Remove the four Torx T8 2.0×4.0 screws.
  4. HP EliteBook 850 G5 Battery Replacement, Remove the battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Rotate the top of the battery upward, and then lift the battery out of the computer.
To replace the battery & reassemble your device, follow these instructions in reverse order.
Max Kletskov
crwdns2935283:004/22/20crwdne2935283:0
41 087 crwdns2915208:0crwdne2915208:0
The Home Depot crwdns2935289:0The Home Depotcrwdne2935289:0
Community
crwdns2931471:019 338crwdne2931471:0
crwdns2935297:0111crwdne2935297:0
Super Anleitung. Keine 10 min da war der Akku getauscht inkl. Reinigung 👍🏼
Marcus van Pluer - crwdns2934203:0crwdne2934203:0
Akkutauschanleitung gut gefunden. Der Austausch war einfach und gut beschrieben.
K. Gnann - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 35
crwdns2936753:030crwdne2936753:0 155
crwdns2942667:0crwdne2942667:0 9,081
