Use this guide to replace a broken or non‑responsive touchpad (aka trackpad) on your HP EliteBook 845 G8 laptop.
You may need to replace the touchpad if it's behaving erratically, unresponsive to touch inputs, or inconsistent in cursor movement.
When handling batteries, don’t use sharp or metal tools, and don’t bend them or use excessive force. If your battery is swollen, take appropriate precautions.
Still under warranty? Contact HP to learn your warranty status, receive a repair under warranty if eligible, or for further warranty information.
Save your work, fully shut down your laptop, and unplug all cables.
Use a Phillips screwdriver to fully loosen (but not remove) the five captive screws securing the bottom cover.
Position your laptop so the rear edge (with the screen hinge) is closest to you.
Insert the flat end of a spudger between the rear edge of the bottom cover and the frame, near the middle screw and ELITEBOOK text.
Use your spudger to pry up the cover to release the clip securing it.
Leave the spudger inserted under the bottom cover for the next step.
Slide your spudger along the rear edge toward one of the corners to release the rear edge clips.
Rotate your spudger around the corner and up the edge to release the clips securing the short edge of the cover.
Reinsert the flat end of a spudger near the ELITEBOOK text.
Repeat the previous step for the other side of the cover to release the remaining clips.
Lift and remove the bottom cover.
Position your laptop so the front edge (opposite the screen hinges) is closest to you.
Use the point of a spudger or your fingernail to push on alternating sides of the battery's sliding connector to walk it completely out of its socket.
Use a Phillips screwdriver to remove the four 4.5 mm‑long screws securing the battery.
Lift the top edge of that battery and slide the tabs on the bottom edge out of their slots.
Remove the battery.
Use a spudger to lift the hinged locking flap on one of the three ZIF connectors near the top right corner of the touchpad.
Use tweezers to gently pull the cable straight out of its socket.
Repeat the previous step to disconnect the two remaining touchpad cables.
Use a spudger or your fingers to lift the entire speaker cable out of its clips on the bottom edge.
Use a Phillips screwdriver to remove the five 2.2 mm‑long screws securing the touchpad.
Lift the bottom corners of the touchpad with your fingers and slide the top edge out from under the motherboard.
Slide the touchpad under the speaker cable and remove it.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Take your e-waste to an R2 or e-Stewards certified recycler. Depending on your region, used HP devices and parts can be returned for reuse or recycling through the HP Planet Partners program.
