This guide is to instruct you in the proper removal and replacement of the Wireless Card in an HP EliteBook 840 G7. Use this guide if your computers Wireless Card stops working.
Use the Phillips # 1 screwdriver to remove the five 1.2 mm screws from the back cover of the laptop.
Den Phillips #1 Schraubenzieher benutzen um die fünf schrauben auf der Rückseite des Laptops zu entfernen
Remove the back cover to expose the hardware.
Use your Phillips #1 screwdriver and remove the four 1.2 mm screws that secures the battery into place.
Remove the connector that connects the battery to the motherboard.
Entferne die Schrauben die die Batterie in Position halten
Lift up the battery with you hands or tools.
Detach both wires from the wireless card.
Use a Phillips # 1 screwdriver, remove the one 2.5 mm screw securing the wireless card.
What model wireless card are you using?
Auf den Rücken drehen
Luis-Oliver Bota - crwdns2934203:0crwdne2934203:0
